    troublems with systemd and serveronly
    7 Posts 2 Posters 1.1k Views 2 Watching
      dnj0104
      Hello I have setup my magicmirror (latest) as follows
      Virtual machine on a dell optiplex running magicmirror serveronly
      Raspberry pi running chromium-browser in kiosk pointing at VM
      BUT when running npm run serveronly on VM my mm-client (raspberrrypi fetch and shows magicmirror interface from server)
      then I stop npm serveronly and make a systemd script as the one in magicmirror documents.
      [Unit]
      Description=MagicMirror
      After=network.target
      StartLimitIntervalSec=0
      [Service]
      Type=simple
      Restart=always
      RestartSec=1
      User=sentinel
      WorkingDirectory=/home/sentinel/MagicMirror/
      ExecStart=/usr/bin/node /home/sentinel/MagicMirror/serveronly
      [Install]
      WantedBy=multi-user.target
      and systemctl start and then status magicmirror.service result in following
      ● magicmirror.service - MagicMirror
           Loaded: loaded (/etc/systemd/system/magicmirror.service; enabled; vendor preset: enabled)
           Active: active (running) since Sun 2024-04-21 18:36:18 CEST; 1ms ago
         Main PID: 1016038 ((node))
            Tasks: 1 (limit: 8826)
           Memory: 256.0K
              CPU: 224us
           CGroup: /system.slice/magicmirror.service
                   └─1016038 (node)
      Apr 21 18:36:18 MagicMirrorVm systemd[1]: Started MagicMirror.
      but after this action my mm-client (raspberry pi) cant connect to server anymore I get “this site cant be reached”
      How do I solve this, to me it seems that mm-serveronly does not start but I’m not sure .
        sdetweil @dnj0104
        @dnj0104 is the vm with desktop.or only text mode?
        I hate systemd setup, it is SO sensitive to os details.
        that is why i use pm2 ( node process manager) in my Installation script.
        try my script fixuppm2
        see
        D 1 Reply Last reply
          dnj0104 @sdetweil
          @sdetweil the VM has only terminal interface I access it with ssh
          oo cool script. shall i run it inside my MagicMirror directory or outside in my user directory or in my root folder ?
            sdetweil @dnj0104
            @dnj0104 script doesn’t care where it is run. assumes ~/MagicMirror
            you would delete the systemd stuff.
            I have not tried the script on cli mode only
            it uses the script at
            ~,/MagicMirror/installers/mm.sh
            it is trying to do npm start
            change it to npm run server
            or node serveronly
              dnj0104 @sdetweil
              Thanks! I will try that, seems smooth.
                dnj0104 @dnj0104
                It worked with the pm2 way ! thanks
                In mm.sh I wrote npm run server and everything is up n runnin again .
                Thanks again !
                  sdetweil @dnj0104
                  @dnj0104 awesome! thanks for the feedback
