    MMM-Navigate, Issues with KY-040 rotary encoder
    15 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @stinkycol
      @stinkycol
      did you try adding tge line to /boot/config.txt
        stinkycol @sdetweil
        Hi, yes I tried that but when editing boot/config there was an entry inside saying it had moved to boot/firmware/config so I added it there.
        S S 2 Replies Last reply Reply Quote 0
          sdetweil @stinkycol
          @stinkycol the dependency for onoff is in the package.json, and would be loaded in the module node_modules folder during npm install
          the fact that you don’t have a black screen error indicates it is installed and I see the module has the updated postinstall step to make sure it has the correct binary level matching the electron version
          did you look at the output of npm start to verify the module loaded correctly?
            stinkycol @stinkycol
            @stinkycol This is the message i see when i try to edit boot/config:
              @sdetweil said in MMM-Navigate, Issues with KY-040 rotary encoder:
              this is what I am looking for
              when you do npm start. MagicMirror puts out message
              if you use pm2 to autolaunch MM during boot
              then the command
              pm2 logs --lines=nn
              where nn is some number of lines to display, default 15
              will display the collected logs…
              generally I recommend NOT using pm2 during module adds and reconfigures to be able to review these messages more easily.
                stinkycol @sdetweil
                Hi, firstly I would like to thank you for helping me out especially as i am so new to this. There are messages on the npm report but I was starting the MM from my terminal on the screen and i didn’t see the messages since the mirror started up and covered them but I have started using Putty and now i can see them. I see that there is an exception that has onoff in the message so perhaps it hasnt been loaded correctly?
                  stinkycol @sdetweil
                  @sdetweil I am using PM2 in my other build but i haven’t implemented it in this one as i just wanted to confirm the KY040 code worked before moving on to autostarting
                    sdetweil @stinkycol
                    @stinkycol pm2 has lots of commands
                    in linux the convention is commands provide help two ways
                    1. using the --help param
                    2. providing a manual page, seen with man program_name
                    pm2 status will show you what is defined and what its state is
                    you can control individual apps (I have 10 defined on one system)
                    with the number of the row that matches their name or the actual name (oops I have 3 MagicMirror apps defined in different locations, so I have to use the row number
                    pm2 stop xx
                    or if you know what they are you can stop them all
                    pm2 stop all
                    you can restart an app too
                    etc…
                      sdetweil @stinkycol
                      @stinkycol i have seen that error on other posts, and it sounds like there are some new tests on setting up the gpio pins.
                      the code wants 3 pins,
                      the node_helper code
                      		console.log('MMM-Navigate, listen on GPIO PINs (BCM): '+self.config.GPIOPins[0]+','+self.config.GPIOPins[1]+','+self.config.GPIOPins[2]);
                      		const CLK = new Gpio(self.config.GPIOPins[1], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 20
                      		const DT = new Gpio(self.config.GPIOPins[0], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 26
                      line 38		const SW = new Gpio(self.config.GPIOPins[2], 'in', 'both',{debounceTimeout : 20 }); //BCM Pin 19
                      the error is on the last, which is the one you added to the boot time config.
                      I think ‘both’ incorrect for this.
                      when you used profileswitcher, what module did you use for connecting the encoder? as that module doesn’t have a hardware component
                        stinkycol @sdetweil
                        @sdetweil I used MMM-GPIO-Notifications as i was using this on my other build to use simple buttons to swap pages.
                        On the latest run I still get the errors:
                        These are the entries in the config.js:
                        This is the npm output as i move the KY040:
                          stinkycol @sdetweil
                          @sdetweil sorry I don’t write understand how you figured that the last one was causing the issue and is this an issue with boot/firmware/config? Did this mean that I should replace the gpio in the MMM-Navigate module on config.js to the sudonyms?
                          GPIOPins:[DT, CLK, SW]
                            sdetweil @stinkycol
                            @stinkycol I looked at the line numbers reported in the stack trace dump that came along w the write error
                            I do not know what the solution is
                              stinkycol @sdetweil
                              @sdetweil OK thanks for trying
                                sdetweil @stinkycol
                                @stinkycol the gpio notifications module does the gpio connection differently
