    Need Help with magicmirror
    15 Posts 2 Posters 2.7k Views 2 Watching
    • W Offline
      WM1600 @sdetweil
      ok,
      I have done those.
      no change
        sdetweil @WM1600
        @WM1600 what is the output of the pm2 logs command? I need to see
        • W Offline
          WM1600 @sdetweil
          the terminal looks like this
          will@raspberrypi:~ $ pm2 logs --lines=50
          I do not see it doing anything.
          [pm2.jpg](Input file contains unsupported image format)
          I tried to upload the PM2.log but it says I can only upload picture files.
          so I changed pm2.log to pm2.jpg. dont know it that will work.
            sdetweil @WM1600
            @WM1600
            ok, let’s do.
            pm2 status to see what apps it is managing
            • W Offline
              WM1600 @sdetweil
              when I type in pm2 status
              I dont see anything
              this is the terminal copied:
              will@raspberrypi:~ $ pm2 status
                sdetweil @WM1600
                @WM1600 hmmm weird
                run the fixuppm2 script from here
                • W Offline
                  WM1600 @sdetweil
                  I ran the following in terminal
                  will@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                  the log will be saved in /home/will/MagicMirror/installers/pm2_setup.log
                  /usr/local/bin/node: 1: Syntax error: “)” unexpected
                  I have seen “Syntax error: “)” unexpected” before but that is the first time I have seen it twice
                  here is the log file:
                  pm2 setup starting - Sun Apr 28 11:19:37 EDT 2024
                  using parameter bash
                  system is Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
                  the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
                  node version v20.12.1
                  force installing latest npm version via npm
                  npm version 10.5.2
                  pm2 installed
                  pm2 installed, but does not work, uninstalling
                  pm2 not installed, installing
                  get the pm2 platform specific startup command
                  startup command =
                  pm2 startup command done
                  configure the pm2 config file for MagicMirror
                  the user is not pi
                  change pm2_MagicMirror.json
                  now using this config file pm2_MagicMirror_new.json
                  start MagicMirror via pm2 now
                  save MagicMirror pm2 config now
                  pm2 setup completed - Sun Apr 28 11:19:39 EDT 2024
                  pm2 setup starting - Sun Apr 28 20:25:03 EDT 2024
                  npm version 10.5.2
                  pm2 installed
                  startup command =
                  the user is not pi
                  pm2 setup completed - Sun Apr 28 20:25:05 EDT 2024
                  it is saying the user is not pi, but this is on a rasberry pi
                    sdetweil @WM1600
                    @WM1600 yes, your username is will, not pi
                    can you do
                    uname -a
                    file $(which bash)
                    I think you have a hybrid system
                    64 bit kernel
                    32 bit runtime
                    and you have the wrong (64 bit) node installed
                    • W Offline
                      WM1600 @sdetweil
                      will@raspberrypi:~ $ uname -a
                      will@raspberrypi:~ $ file $(which bash)
                      /usr/bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
                        sdetweil @WM1600
                        @WM1600 ok then…
                        hm… trying to figure out the best way to fix this
                        the bad node install is hard to get out of.
                        I think redoing the sd card is the cleanest
                        use my backup script to save the MagicMirror setup.
                        https://github.com/sdetweil/MagicMirror-backup-restore
                        it’s three files plus any addon files made by modules, like the token file for photos
                        one little directory.
                        if you use github then it can save all that to a private repo u build on github.
                        otherwise copy the folder off somewhere you can get it back
                        make the new sd card,
                        boot, don’t update during bootup
                        install MagicMirror using my install script
                        which will update node/npm too
                        then restore your MagicMirror setup
