    Show calendar based on IP Address accessed
    68 Posts 3 Posters 35.4k Views 3 Watching
      MMRIZE @Spinster
      @Spinster
      I’m out of my test PC, so I can’t show atm. (Maybe tomorrow possible, if you couldn’t success until that time)
      You can add custom config attribute map-like object calendarMap in your config.js
        calendarMap: {
          "192.168.178.100": ["calendar1", "calendar2"],
          "192.168.178.101": ["calebdar1", "calendar3"],
            url: " … ",
      In calendar.js around line 176, when CALENDAR_EVENTS notification coming, you can filter the payload(array of events) of that notification by checking calendarName of each event is matched to this.config.calendarMap.
      Sorry I can’t show the real code now. Maybe some hours later I may be able to. Anyway concept would be like this.
        Spinster @MMRIZE
        @MMRIZE Great, You have given me an idea, will wait for your code. Please share when possible.
          MMRIZE @Spinster
          @Spinster
          Ah I suddenly remember that getting Internal IP with only JavaScript on client browseris hard.
          Hmmm another approach might be needed.
            sdetweil @MMRIZE
            @MMRIZE that is why you need the express api call…
            I would make a separate module that has ip in div, not shown, but w id
            then call in calendar is document.get…
            compare, your way or on cal entries
            more synchronous…
              MMRIZE @sdetweil
              Yes. I thought a small module with node_helper that could return clients’ ip as a result of REST api call from calendar module.
                sdetweil @MMRIZE
                @MMRIZE and that module calls its own rest call publishes the address in its getDom() result, with id= on div
                and then cal module can use synchronous document.getElementsById()
                to get that value.
                  @MMRIZE @Spinster
                  so the little module is
                  https://github.com/sdetweil/getip
                  and it does correctly return the ip address of the client… tested from 4 different systems to the same MM…
                  see later post for final solution
                    Spinster @sdetweil
                    @sdetweil @MMRIZE
                    Wow, you are quick, you have given me some homework. Will use your code and get back with the result.
                    Thank you so much for your patience and understanding.
                      Spinster @sdetweil
                      I tried your code, but find that once I include getip module in config.js, I am not seeing any output for calendar. Is this the expected output. Without getip module, I find that client_ip = document.getElementById("getip is returning null.Please advice
                      S M 3 Replies Last reply Reply Quote 0
                        sdetweil @Spinster
                        @Spinstersee later post
                          MMRIZE @Spinster
                          @Spinster
                          By the way, which client are you using? Electron? Or Browser?
                            Spinster @MMRIZE
                            @MMRIZE Browser as of now.
                            I also tried using express ipfilter, but the problem is I don’t know how to use it in module.js, it is throwing error saying ipfilter not known etc
                              sdetweil @Spinster
                              @Spinster well, here is a working example, in addition to the other code already
                              watch out if using address AND MM host system not included. as it won’t show either…
                              one could make the ipaddress in cal a list (of ip addresses) similar to what @MMRIZE does…
                              I don’t like adding the extra block,
                              just add the var to the thing that matters…
                              see later post
                                MMRIZE @Spinster
                                @Spinster
                                With getip of @sdetweil and MMM-ModuleMonkeyPatch, I did it. (You don’t have to modify the original source code for future-proof.)
                                Example.
                                Server is running on 192.168.178.63 and I run 2 clients on 192.168.178.22 and 192.168.178.63.
                                Both 2 clients can show different set of calendars.
                                	module: "MMM-ModuleMonkeyPatch",
                                		patches: [
                                				method: "socketNotificationReceived",
                                				patch: async function (original, args) {
                                					const [ notification, payload ] = args
                                					if (notification === "CALENDAR_EVENTS") {
                                						const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
                                						const r = await fetch('http://192.168.178.63:8080/modules/getip')
                                						const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
                                						if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
                                							return original(notification, { ...payload, events: [] })
                                					return original(notification, payload)
                                	module: "getip",
                                	header: "US Holidays",
                                		clientMap: {
                                			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
                                			"192.168.178.22": ["cal3", "cal4", "cal5"]
                                				url: "...",
                                				url: "...",
                                				url: "...",
                                				url: "...",
                                				url: "...",
                                TO Improve
                                Whenever notification CALENDAR_EVENTS coming, getip is called. After first execution, to store IP on the localStorage or cookie would be better.
                                S S 2 Replies Last reply Reply Quote 0
                                  Spinster @sdetweil
                                  @sdetweil will express ipfilter be useful? Similar to whitelist, can we try something
                                    sdetweil @Spinster
                                    @Spinster no… as its in the wrong place… (inside node_helper…) we NEED the ip address to compare with
                                    just get it and return . one time
                                      sdetweil @MMRIZE
                                      @MMRIZE said in Show calendar based on IP Address accessed:
                                      BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
                                      that have to be processed… this is a bad waste of resources…
                                      and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
                                      this could also lead to different clients showing different data between fetchIntervals…
                                        MMRIZE @sdetweil
                                        @sdetweil said in Show calendar based on IP Address accessed:
                                        I Can’t understand your point.
                                        My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
                                          MMRIZE @sdetweil
                                          Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
                                          Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
                                            sdetweil @MMRIZE
                                            @MMRIZE yes
                                            @Spinster
                                            see later post
                                            • 1 / 4
