    MMM-MyCommute not showing
    12 Posts 2 Posters 3.3k Views 2 Watching
      semihbakrac @sdetweil
      @sdetweil Why are there two? Also Mycommute does not appear on the screen
        sdetweil @semihbakrac
        @semihbakrac why are there two… use did the setup manually and created the mm one
        and then you used my script and replied yes to pm2, and I created one
        you can delete either
        pm2 delete xxx
        pm2 save
          @semihbakrac pm2 separates the errors and good output into two different files
          and displays them separately when using the pm2 logs command
          that is the good output
          I always recommend NOT using pm2 when changing config, adding a module
          pm2 stop all
          npm start
          once you have it running like you want
          then pm2 start xxx
            @sdetweil Only mycommute doesn’t work. npm log is this
            semihbakrac@raspberrypi:~/MagicMirror $ npm start
            > magicmirror@2.27.0 start
            [2024-05-18 22:59:01.677] [LOG]   Starting MagicMirror: v2.27.0
            [2024-05-18 22:59:01.735] [LOG]   Loading config ...
            [2024-05-18 22:59:01.743] [LOG]   config template file not exists, no envsubst
            [2024-05-18 22:59:01.755] [LOG]   Loading module helpers ...
            [2024-05-18 22:59:01.758] [LOG]   No helper found for module: alert.
            [2024-05-18 22:59:02.424] [LOG]   Initializing new module helper ...
            [2024-05-18 22:59:02.425] [LOG]   Module helper loaded: updatenotification
            [2024-05-18 22:59:02.427] [LOG]   No helper found for module: clock.
            [2024-05-18 22:59:02.822] [LOG]   Initializing new module helper ...
            [2024-05-18 22:59:02.824] [LOG]   Module helper loaded: calendar
            [2024-05-18 22:59:02.825] [LOG]   No helper found for module: weather.
            [2024-05-18 22:59:03.625] [LOG]   Initializing new module helper ...
            [2024-05-18 22:59:03.626] [LOG]   Module helper loaded: MMM-MyCommute
            [2024-05-18 22:59:04.306] [LOG]   Initializing new module helper ...
            [2024-05-18 22:59:04.307] [LOG]   Module helper loaded: MMM-MyPrayerTimes
            [2024-05-18 22:59:04.308] [LOG]   All module helpers loaded.
            [2024-05-18 22:59:04.322] [LOG]   Starting server on port 8080 ...
            [2024-05-18 22:59:07.200] [LOG]   Server started ...
            [2024-05-18 22:59:07.203] [LOG]   Connecting socket for: updatenotification
            [2024-05-18 22:59:07.205] [LOG]   Starting module helper: updatenotification
            [2024-05-18 22:59:07.207] [LOG]   Connecting socket for: calendar
            [2024-05-18 22:59:07.209] [LOG]   Starting node helper for: calendar
            [2024-05-18 22:59:07.211] [LOG]   Connecting socket for: MMM-MyCommute
            [2024-05-18 22:59:07.213] [LOG]   ====================== Starting node_helper for module [MMM-MyCommute]
            [2024-05-18 22:59:07.215] [LOG]   Connecting socket for: MMM-MyPrayerTimes
            [2024-05-18 22:59:07.217] [LOG]   Starting node_helper for: MMM-MyPrayerTimes
            [2024-05-18 22:59:07.219] [LOG]   Sockets connected & modules started ...
            [2024-05-18 22:59:07.870] [LOG]   Launching application.
            [2024-05-18 22:59:10.593] [INFO]  System information:
            ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
            ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 12; arch: arm; kernel: 6.6.28+rpt-rpi-v7
            ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
            ### OTHER:    timeZone: Europe/Istanbul; ELECTRON_ENABLE_GPU: undefined
            [2024-05-18 22:59:13.101] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/semih342bakrac%40gmail.com/private-c2fb4dce86cf995b9f980010988f5bf9/basic.ics - Interval: 604800000
            [2024-05-18 22:59:13.397] [INFO]  updatenotification: Updater Class Loaded!
            [2024-05-18 22:59:13.399] [INFO]  updatenotification: Checking PM2 using...
            [2024-05-18 22:59:13.404] [INFO]  Checking git for module: MMM-MyCommute
            [2024-05-18 22:59:13.468] [INFO]  Checking git for module: MMM-MyPrayerTimes
            [2024-05-18 22:59:13.539] [INFO]  Checking git for module: MagicMirror
            [2024-05-18 22:59:13.592] [INFO]  updatenotification: [PM2] You are not using pm2
            [2024-05-18 22:59:13.811] [LOG]   200[object Object]
            [2024-05-18 22:59:14.196] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://calendar.google.com/calendar/ical/semih342bakrac%40gmail.com/private-c2fb4dce86cf995b9f980010988f5bf9/basic.ics.
              @semihbakrac said in MMM-MyCommute not showing:
              MMM-MyCommute
              your config looks something like this… with proper start and end and the
              google api key
                module: 'MMM-MyCommute',
                position: 'top_left',
                  apikey: 'API_KEY_FROM_GOOGLE',
                  origin: '65 Front St W, Toronto, ON M5J 1E6',
                  startTime: '00:00',
                  endTime: '23:59',
                  hideDays: [0,6],
                  destinations: [
                      destination: '14 Duncan St Toronto, ON M5H 3G8',
                      label: 'Air Canada Centre',
                      mode: 'walking',
                      color: '#82E5AA'
                      destination: '317 Dundas St W, Toronto, ON M5T 1G4',
                      label: 'Art Gallery of Ontario',
                      mode: 'transit'
                      destination: '55 Mill St, Toronto, ON M5A 3C4',
                      label: 'Distillery District',
                      mode: 'bicycling'
                      destination: '6301 Silver Dart Dr, Mississauga, ON L5P 1B2',
                      label: 'Pearson Airport',
                      avoid: 'tolls'
                @sdetweil my config
                  			position: 'top_right',
                			header: 'Tahmin Edilen Varis Suresi',
                    				apikey: 'myAPI',
                    				origin: 'Menderes, 381. Sk. 13-1, 34225 Esenler/Istanbul',
                    				startTime: '00:00',
                    				endTime: '23:59',
                    				hideDays: [0,6],
                    				destinations: [
                        				destination: 'Sekerpinar, Otomotiv Cd. No:2, 41435 CAYIROVA/Cayirova/Kocaeli',
                        				label: 'Araba',
                        				mode: 'driving',
                					alternatives: true,
                        				label: 'Toplu Tasima',
                        				mode: 'transit'
                        				destination: 'Halicioglu, 34445 Beyoglu/Istanbul',
                        				label: 'Servis Kalkis Noktasi',
                        				mode: 'transit'
                  hideDays: [0,6],
                  so, you hid all the days??
                  I edited out everything but this module def
                    @sdetweil omg. My brain is not working. I’m sorry to keep you busy :((( . Thanks for support
                    • S semihbakrac has marked this topic as solved on
                    • S semihbakrac has marked this topic as unsolved on
                      @sdetweil I can only color the driving icon. I cannot color other icons. Bus,subway etc. The application acts as if the config file does not exist and only the warning screen appears. Do you know anything about this?
                        @semihbakrac sorry, know nothing about the internals…
