    Default calendar module with iCloud calendar fetch error
    6 Posts 2 Posters 269 Views 2 Watching
      sdetweil @autistiii
      @autistiii yes
      http://ip-address/modules/calendars/c4684ce4-3887-496a-ae4a-23eab8dacbb2.ics
      MagicMirror is running on port 8080 or whatever is configured in the config.js
      port property
      without a port number specified, it means port 80
      http://ip_address:8080/…
        autistiii @sdetweil
        thank you for the fast response.
        however, adding the port “:8080” to the ip-address in the config file doesnt solve the issue :/
        the error message is still the same
          sdetweil @autistiii
          @autistiii said in Default calendar module with iCloud calendar fetch error:
          cause: Error: connect ECONNREFUSED ip-address:80
          that error?
            autistiii @sdetweil
            yes
            cause: Error: connect ECONNREFUSED ip-adress:8080
              sdetweil @autistiii
              @autistiii what is ip_address?
              localhost?
              if NOT then you have to open up access permissions
              by changing the config.js
              address and ipWhitelist properties
