    Switch URL based on value
    10 Posts 3 Posters 1.4k Views 3 Watching
    • htilburgsH
      htilburgs
      In the script it will assume you have 2 different IP addresses to query an URL.
      1 IP for the HomeWizard P1 meter
      1 IP for the HomeWizard Water Meter
      This is because I like to show the information of both in 1 script. Everything works fine if both are used, but when someone only has the P1 meter, the IP for the Water Meter is not used and results in a console fetch error (normal behavior)
      [ERROR] Error: TypeError: fetch failed
          at node:internal/deps/undici/undici:13178:13
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
        [cause]: Error: getaddrinfo ENOTFOUND null
            at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
          errno: -3008,
          code: 'ENOTFOUND',
          syscall: 'getaddrinfo',
          hostname: 'null'
      Is there a way to switch URL in case one of both URL are NULL? I’ve tried, but it doesn’t work with if-else
      	start: function () {
      		requiresVersion: "2.9.0",
      		// Set locales
      		if (this.config.P1_IP != null) {
      			this.urlP1 = "http://" + this.config.P1_IP + "/api/v1/data/";
      		} else {
      			this.urlP1 = "https://dummyjson.com/c/7e24-36ab-48e0-a96d";
      		if (this.config.WM_IP != null) {
      			this.urlWM = "http://" + this.config.WM_IP + "/api/v1/data/";
      		} else {
      			this.urlWM = "https://dummyjson.com/c/704a-9a96-4845-bc72";
          		this.MHW_P1 = [];	        // <-- Create empty MHW_P1 array
      		this.MHW_WM = [];		// <-- Create empty MHW_WM array
      		this.scheduleUpdate();       	// <-- When the module updates (see below)
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • htilburgsH
        htilburgs @sdetweil
        Meanwhile I was doing this, and I found the error (stupid me)
        		requiresVersion: "2.9.0";
        		// Set locales
        		} else {
        		} else {
        //		this.urlP1 = "http://" + this.config.P1_IP + "/api/v1/data/";
        //		this.urlWM = "http://" + this.config.WM_IP + "/api/v1/data/";
        The line with "requiresVersion: “2.9.0”; " was ending with an “,” instead of “;”
        without the “if” statement, I don’t get a failure with a “,”
        So changed it now into “;” and everythins seems to work.
        I continue testing.
        @MMRIZE Thanks for the alternative way. I’m going to look into it.
        So with the “promise” statement, it looks like I can eleminate the node_helper.js
        S 2 Replies Last reply
          sdetweil @htilburgs
          @htilburgs said in Switch URL based on value:
          what is the setting for that in the defaults:{} section?
          htilburgsH 1 Reply Last reply
          • htilburgsH
            htilburgs @sdetweil
            	// Default values
            	defaults: {
            		P1_IP: null,				// IP Address P1 Meter
            		WM_IP: null,				// IP Address Water Meter
            		maxWidth: "500px",			// Max width wrapper
            		extraInfo: false,			// Show extra information
            		showFooter: false,			// Show footer (name Power Meter)
            		currentPower: true,			// Show current power usage
            		initialLoadDelay: 1000,
            		updateInterval: 10000			// Every 10 seconds
            M S 2 Replies Last reply
              MMRIZE @htilburgs
              @htilburgs
              Just for your reference
              const ip_a = "..."
              const ip_b = "..."
              const apiQuery = (index, url) => {
                if (!url) return Promise.reject({ index, reason: 'url is not defined' })
                return new Promise((resolve, reject) => {
                  try {
                    fetch(url)
                      .then(response => response.json())
                      .then(data => {
                        resolve({ index, value: data })
                      .catch(error => {
                        reject({ index, reason: error })
                  } catch (error) {
              const queries = []
              queries.push(apiQuery('A', ip_a))
              queries.push(apiQuery('B', ip_b))
              Promise.allSettled(queries).then((results) => {
                console.log('All jobs are done')
                results.values().forEach((result) => {
                  if (result.status === 'fulfilled') {
                    console.log(`Index: ${result.value.index}, Value:`, result.value.value)
                  } else {
                    console.log(`Index: ${result.reason.index}, Error:`, result.reason.reason)
                sdetweil @htilburgs
                @htilburgs hm… looks ok, I would use the developer window sources tab to debug the code and look at the variables… (mouse over name usage will show contents)
                • htilburgsH
                  htilburgs @sdetweil
                  In the console - sources it says:
                  Uncaught SyntaxError: Unexpected token 'if'
                    sdetweil @htilburgs
                    @htilburgs well, if the code breaks, then …
                    so, look at that line and see what is missing from before it
                    a quick way to find syntax errors
                    in the module folder, run the pre-compiler to check for errors
                    node -c modulename.js
                    (or any js file)
                    • htilburgsH
                      htilburgs @sdetweil
                      		// Set locales
                      		} else {
                      		} else {
                      I continue testing.
                        sdetweil @htilburgs
                        requiresVersion should be outside the start function… (and then needs a trailing comma
                          sdetweil @htilburgs
                          correct, now that electron (and nodejs) have fetch built in(since node 18), you don’t NEED to use node_helper to do it
