    Not loading one of two Google calendars
    14 Posts 2 Posters 4.8k Views 2 Watching
      sdetweil @bdeelman
      @bdeelman can you show me the config for the module, xxx out the url as here
      how many events are in there
      bdeelmanB 1 Reply Last reply Reply Quote 0
        sdetweil @bdeelman
        @bdeelman also, can you look in the log output for any error messages
        log is where you do npm start
        if you are using pm2 to launch MagicMirror
        then
        pm2 logs --lines=nnn
        where nnn is the nunbrr of lines to show, default 15
        • bdeelmanB Offline
          bdeelman @sdetweil
          Hi Sam,
          Total number of events: 3080. 58 upcoming. So maybe too much?
          I use MM at a Docker and that did not use PM2. The one from karsten13.
          Ton of DEBUG with no errors. He is spitting all VEVENT form the past years.
          KR,
          Bert
            sdetweil @bdeelman
            @bdeelman yes, the calendar source sends everything, so its a memory hog, and i think we run out of memory.
            another person reported similar problem
            also if you have maxevents set that includes past events
            ive thought of a fix for that, but havent come up with a good answer
            we have maximumnumber of days so we look forward AND back that range, default a year. but that’s 2 years.
            what part of that range is important?
            then we have maxevents. starting at either end is wrong. but we start at the oldest. might never have any future events in the max range
            i think there should be two lists
            all old
            future, limited by days/max events
            but no one expects two lists (breaking part)
            another hacky way is one list. we find today and the apply limits on the forward part
            • bdeelmanB Offline
              bdeelman @sdetweil
              Hi Sam,
              The upcoming events are important. Always looking forward ;)
              Is there a way setting variables to fix it? I can remove all old events from Google, but why? Maybe we need to import only future events.
              What will be the best solution?
              KR,
              Bert
                sdetweil @bdeelman
                @bdeelman we cannot import only future
                we get everything the source provides when we ask for the events. google doesn’t provide a filter mechanism
                we dont parse them directly , calling a 3rd party
                lib. but they have to parse them so we can filter. and boom we die before we can filter.
                future is important. a year out? a day? a week?
                i have a rolling 3 month future view. ( was a test, but i find it useful)
                but even my all old, limited future idea doesn’t solve the total size problem
                we are publishing a bunch of fixes i have created for calendar jan 1
                this issue remains open.
                would you be willing to share your cal url, via direct message, so i can test? i don’t share any data w others
                • bdeelmanB Offline
                  bdeelman @sdetweil
                  Hi Sam,
                  I’ll generate a .ics calendar file with 4500 events, including a mix of:
                  Single events: Appointments, meetings, etc.
                  Recurring events: Weekly or yearly recurrences for things like birthdays, anniversaries.
                  Time ranges: Events spanning multiple hours or days.
                  The events will cover the period from January 1st, 2019 to January 1st, 2026.
                  I can put it at a website if you want? If you need an URL.
                  KR,
                  Bert
                    sdetweil @bdeelman
                    @bdeelman tell me where it is so I can download, will advise when done
                    make sure it fails of course, to test
                    put it in a directory off the MM folder then
                    then url in cal
                    http://localhost:mm_port/path/to_ics.file
                    • bdeelmanB Offline
                      bdeelman @sdetweil
                      Hi Sam,
                      What I did, with some help of ChatGPT.
                      The newly random events are working flawless. I prepared Python script to check the quality of the Google .ics file. I have 3071 events and 9 of them gave an error.
                      Error parsing event: 'NoneType' object has no attribute 'dt'
                      Indicates that one of the events in my .ics file has a missing or improperly formatted DTSTART or DTEND.
                      I made another script to check how much. Nine 9 events has missing date fields. Another script to remove those 9 entries and load it into MM. And now they show up.
                      But…then I saw an error at the console at the customEvents parts.
                                  keyword: "Verjaardag",
                                  symbol: "birthday-cake",
                                  color: "Gold",
                                  transform: {
                                    search: "^([^']*) '(\\d{4})$",
                                    replace: "$1 ($2.)",
                                    yearmatchgroup: 2,
                      But with this code the other Google ics was working. Strange, without this code the two Google ics are working. So not sure if commenting the customEvents did the trick.
                      I can’t revert because I deleted the “wrong” events from the calendar.
                      KR,
                      Bert
                        sdetweil @bdeelman
                        @bdeelman ok, we dont have a dt property, so that might have been a python issue
                        its ok to have start without an end , the library handles that
                        do you know what the customevents error was?
                        • bdeelmanB Offline
                          bdeelman
                          Hi Sam,
                          [calendarutils.js:112 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'length')
                              at Object.titleTransform (calendarutils.js:112:24)
                              at calendar.js:353:41
                              at Array.forEach (<anonymous>)
                              at Class.getDom (calendar.js:255:10)
                              at main.js:132:35
                              at new Promise (<anonymous>)
                              at updateDom (main.js:112:10)
                              at Object.updateDom (main.js:669:4)
                              at Class.updateDom (module.js:341:6)
                              at Class.socketNotificationReceived (calendar.js:210:8)](link url)
                          But also with this error, both .ics are loading.
                          KR,
                          Bert
                            sdetweil @bdeelman
                            @bdeelman thx. the transform is expecting something in the title. dont know.
                            • bdeelmanB Offline
                              bdeelman
                              The second Google calendar was too big. I made a module to prepare a smaller ics file with only the future events.
                              And now it is working. Two Google calendars.
                              KR,
                              Bert
