    Visibility of variables in MMM-HomeAssistantDisplay
    8 Posts 2 Posters 867 Views 2 Watching
      DrKaMo @sdetweil
      this is the code, I would like if a fixed is closed (status false) that this is not displayed. Unfortunately this was not displayed in your link.
        sdetweil @DrKaMo
        @DrKaMo said in Visibility of variables:
        what is a ‘fixed’?
          DrKaMo @sdetweil
          @sdetweil I only want to display the windows that are open. I have already tried this link but apparently my variable does not have the state bit but only the bit itself.
            sdetweil @DrKaMo
            @DrKaMo I have a garage door that is a ‘cover’ type device
            my config (copied from the sample )
            let perimeterWindowSections = [];
            perimeterWindows.forEach((item, i) => {
                perimeterWindowSections.push({
                    triggerEntities: [
                        item.entity
                    displayTemplate: `
                    {% if states.${item.entity}.state == "open" %}<i class='mdi mdi-window-open'></i> ${item.name}{% endif %}
                    class: "window"
            and it changes immediately when the door is opened and closed…
            if I change entity state === ‘closed’ then it shows(as it IS closed) when closed , and not if its ‘open’
            the module config itself
                module: 'MMM-HomeAssistantDisplay',
                position: 'top_right',
                classes:"page2",
                    host: "xxx",
                    token: "..",
                    port: 8123,
                    useTLS: false,
                    title: "Open Windows",
                    useModuleTigger: false,
                    class: "windows",
                    sections: [
                        ...perimeterWindowSections,
            I also used a light switch
             {% if states.${item.entity}.state == "on" %}<i class='mdi mdi-window-open'></i> ${item.name}{% endif %}
            and it worked as expected, and the MM display responded immediately
            so it looks like just getting the entity state value is what you need
            if the entity is a switch , the states are on and off
            if the entity is a cover, then the states are open and closed
            and I checked with a binary sensor
                  entity: "binary_sensor.athom_garage_door_status",
            and it is on or off
              sdetweil @DrKaMo
              @DrKaMo did you resolve this?
