    How to turn compliments blue?
    3 Posts 2 Posters 1.2k Views 2 Watching
      raspberrypi9
      I would like the compliments text of the default compliments module to be in blue instead of white. I think this can be done with custom css but I struggled with the instructions in the pinned post. If someone would please give me a shortcut of how to do it, I would really appreciate your help.
        sdetweil @raspberrypi9
        @raspberrypi9 which pinned post?
        the doc
        says there is a classes config property
           module: "compliments",
           position:"....",
           config:{
               classes:"thin xlarge bright",   // default if not specified
        so, you could override one of those
        .compliments .xlarge {
             color: xxxxx;
        or you could add another classname and configure that
           position:"....",
           config:{
               classes:"thin xlarge bright foo",   // default if not specified, this replaces entire list
        like this
        .compliments .foo {
             color: xxxxx;
          raspberrypi9
          That worked great! Thank you so much for taking the time to answer my question.
