    CalendarExt3 eventTransformer and refreshInterval
    4 Posts 3 Posters 650 Views 3 Watching
    • F Offline
      fXtra
      Hello everyone,
      I am using a Raspberry Pi 5 with the latest MM version and the latest version of the MMM-CalendarExt3 module.
      I would like to display the garbage emptying which works so far. Unfortunately, the ics feed in the title provides all the different garbage cans that are emptied, e.g.:
          "title": "Restmülltonne, Biotonne, Altpapiertonne, Gelbe Tonne",
      My goal was to display icons in different colors in the title.
      In detail:
      Restmülltonne = Black garbage icon
      Biotonne = Brown garbage icon
      Altpapiertonne = Blue garbage icon
      Gelbe Tonne = Yellow garbage icon
      This also works so far, but when the refreshInterval of the MMM-CalendarExt3 takes effect, the eventTransformer is apparently no longer executed correctly in my case.
      Here is a shortened version of the configuration with which you can recreate the problem:
      let config = {
          address: "0.0.0.0",
          port: 8080,
          basePath: "/",
          ipWhitelist: [],
          useHttps: false,
          httpsPrivateKey: "",
          httpsCertificate: "",
          language: "de",
          locale: "de-DE",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          timeFormat: 24,
          units: "metric",
              // ***** CALENDAR MODULES *****
                  module: "MMM-CalendarExt3",
                  position: "top_bar",
                      firstDayOfWeek: 1,
                      refreshInterval: 6000,
                      weeksInView: 4,
                      useMarquee: true,
                      maxEventLines: 4,
                      customHeader: false,
                      eventFilter: (ev) => {
                          if (ev.calendarName === "Trash") {
                              let relevantTitles = ["Restmülltonne", "Biotonne", "Gelbe Tonne", "Blaue Tonne"];
                              return relevantTitles.some(title => ev.title.includes(title));
                          return true;
                      eventTransformer: (ev) => {
                              const trash = [];
                              const strArray = ev.description.split(',').map(item => item.trim());
                              console.log(ev)
                              for (let item of strArray) {
                                  if (item === "Restmülltonne") trash.push("fa-solid fa-trash trash-black");
                                  else if (item === "Biotonne") trash.push("fa-solid fa-trash trash-brown");
                                  else if (item === "Gelbe Tonne") trash.push("fa-solid fa-trash trash-yellow");
                                  else if (item === "Altpapiertonne") trash.push("fa-solid fa-trash trash-blue");
                              ev.description = trash.join(', ');
                              ev.symbol = trash;
                              if (trash.length === 0) {
                                  ev.symbol = [];
                                  ev.color = "none";
                          return ev;
                  header: "Termine",
                      broadcastPastEvents: true,
                      maximumEntries: 10000,
                              fetchInterval: 3000,
                              useSymbol: false,
                              url: "webcal://-849/feed.ics",
                              color: "none"
      if (typeof module !== "undefined") {
          module.exports = config;
      Does anyone have any ideas or is there perhaps a better way to solve the problem?
      Thanks in advance
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @fXtra
        @fXtra i edited your post to remove most of the calendar url
          chrisfr1976 @fXtra
          @fXtra
          This is my code in ext3 config and it does its job:
          			    if (ev.title.search('Altpapier') > -1) {
          			        ev.color = 'blue';
          			        ev.symbol = ['noto:rolled-up-newspaper'];
          			    if (ev.title.search('LVP') > -1) {
          			        ev.color = 'yellow';
          			        ev.symbol = ['noto:recycling-symbol'];
          			    if (ev.title.search('Biotonne') > -1) {
          			        ev.color = 'brown';
          			        ev.symbol = ['noto:biohazard'];
          			    if (ev.title.search('Restmüll') > -1) {
          			        ev.color = 'gray';
          			        ev.symbol = ['noto:squinting-face-with-tongue'];
          			    return ev;
          Regards, Chris.
          • F Offline
            fXtra @chrisfr1976
            @chrisfr1976
            Thank you for sharing. This helped me it seems it was an issue with my conditions using the ev.title.search(‘string’) solved my issue.
                                    const trash = [];
                                    ev.color = 'gray';
                                    if (ev.title.search('Altpapiertonne') > -1) {
                                    if (ev.title.search('Gelbe Tonne') > -1) {
                                    if (ev.title.search('Restmülltonne') > -1) {
                                    ev.symbol = trash;
                                        ev.symbol = [];
                                        ev.color = "none";
                                return ev;
            alt text
            • F fXtra has marked this topic as solved on
