    Error on loading .css
    9 Posts 3 Posters 3.7k Views 3 Watching
    • bdeelmanB Offline
      bdeelman
      I use the Docker image of karsten13/magicmirror:latest
      Since a week I’ve got these error messages at the Console.
      192.168.1.66/:1 Refused to apply style from ‘http://192.168.1.66:4885/css/roboto.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
      192.168.1.66/:1 Refused to apply style from ‘http://192.168.1.66:4885/css/font-awesome.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
      loader.js:205 Error on loading stylesheet: css/font-awesome.css
      Any ideas how to fix this?
      KR,
      Bert
      S karsten13K 3 Replies Last reply Reply Quote 0
        sdetweil @bdeelman
        @bdeelman I think this is a migration problem, @karsten13 have any guesses?
        these used to be in the fonts folder, but it was collapsed and are now present in css folder
        I see them in the correct folder on my docker instance
        custom.css  custom.css.sample  font-awesome.css  main.css  roboto.css
        I see the links in the head section of the MM page
        <link rel="stylesheet" type="text/css" href="css/roboto.css">
        <link rel="stylesheet" type="text/css" href="css/font-awesome.css">
          sdetweil @bdeelman
          @bdeelman can you look on the docker host
          ls magicmirror/mounts/css  -laF
          i see this
          -rwxrwxrwx  1 1000  1000     0 Jan 16 08:38 custom.css*
          -rwxrwxrwx  1 1000  1000   757 Jul  6 02:00 custom.css.sample*
          -rwxr-xr-x  1 1000  1000   161 Jul  6 02:00 font-awesome.css*
          -rwxrwxrwx  1 1000  1000  3985 Jul  6 02:00 main.css*
          -rwxr-xr-x  1 1000  1000 26965 Jul  6 02:00 roboto.css*
          • karsten13K Offline
            karsten13 @bdeelman
            @bdeelman
            show us your setup. How did you start the container? If with the provided setup goto the magicmirror/run dir and show the output of docker compose config and output of cat .env, if with a docker run ... command show the full command.
            I suspect you are using an outdated setup which mounts the whole css dir instead only custom.css file, I changed this a few months ago …
            S bdeelmanB 2 Replies Last reply Reply Quote 0
              sdetweil @karsten13
              @karsten13 said in Error on loading .css:
              I’m sorry, I don’t understand your words here
              we should expose the folder for users that want/need to load other font libraries
              this is my docker compose config output
              magicmirror:
                  container_name: mm
                  environment:
                    HOST_HOSTNAME: ds-data
                    MM_CUSTOMCSS_FILE: css/custom.css
                    MM_MODULES_DIR: modules
                    MM_OVERRIDE_CSS: "true"
                    MM_OVERRIDE_DEFAULT_MODULES: "true"
                    MM_SCENARIO: server
                    MM_SHOW_CURSOR: "false"
                  image: karsten13/magicmirror:latest
                  networks:
                    default: null
                  ports:
                    - mode: ingress
                      target: 8080
                      published: "8080"
                      protocol: tcp
                    - mode: ingress
                      target: 9000
                      published: "9000"
                      protocol: tcp
                  restart: unless-stopped
                  volumes:
                    - type: bind
                      source: /var/services/homes/sam/magicmirror/mounts/config
                      target: /opt/magic_mirror/config
                      bind:
                        create_host_path: true
                    - type: bind
                      source: /var/services/homes/sam/magicmirror/mounts/modules
                      target: /opt/magic_mirror/modules
                      bind:
                    - type: bind
                      source: /var/services/homes/sam/magicmirror/mounts/css
                      target: /opt/magic_mirror/css
                      bind:
                karsten13 @sdetweil
                I changed the setup for css to
                      - type: bind
                        source: /var/services/homes/sam/magicmirror/mounts/css/custom.css
                        target: /opt/magic_mirror/css/custom.css
                        bind:
                It was a design mistake in the beginning to mount the whole folder instead the single file.
                This is maybe not backward compatibel for all old setups.
                • bdeelmanB Offline
                  bdeelman @karsten13
                  Thanks for your reply.
                  I use portainer and Watchtower to automatic upgrade the Docker image. This is the stack I use:
                  version: '3'
                  services:
                    magicmirror:
                      container_name: magicmirror-1
                      cap_add:
                        - NET_ADMIN
                        - NET_RAW
                      network_mode: deellan
                      ports:
                        - "4885:8080"
                      volumes:
                        - /volume2/docker/magicmirror-1/config:/opt/magic_mirror/config
                        - /volume2/docker/magicmirror-1/modules:/opt/magic_mirror/modules
                        - /volume2/docker/magicmirror-1/css:/opt/magic_mirror/css
                      command:
                        - npm
                        - run
                        - server
                    karsten13 @bdeelman
                    @bdeelman said in Error on loading .css:
                    • /volume2/docker/magicmirror-1/css:/opt/magic_mirror/css
                    then try it with changing the above line to
                    - /volume2/docker/magicmirror-1/css/custom.css:/opt/magic_mirror/css/custom.css
                    bdeelmanB 1 Reply Last reply Reply Quote 0
                    • bdeelmanB Offline
                      bdeelman @karsten13
                      @karsten13
                      That did the trick! Thanks.
                      KR,
                      Bert
