    PM2 autostart script not working since last MM update
    6 Posts 2 Posters 765 Views 2 Watching
      meshuggahn
      Hi all,
      Since the last MM update my pm2 autostart script has not been working. Im pretty sure Ive updated all of the supporting software, but let me know if there is a version of anything I should double check.
      The mm.sh script is as posted and worked fine before the update:
      cd ./MagicMirror
      DISPLAY=:0 npm run start
      pm2 logs shows:
      /home/rpi/mm.sh: line 2: npm: command not found
      When I run npm run start in the terminal everything starts up just fine.
      What did I miss?
        sdetweil @meshuggahn
        @meshuggahn how did you update MagicMirror ?
        my script or manually ?
        can you show the output of
        which npm
          meshuggahn @sdetweil
          which npm gives:
          /run/user/1000/fnm_multishells/23578_1753385757014/bin/npm
          npm -v gives:
          11.4.0
            @meshuggahn what os is this?
            i expected /usr/bin/npm
            or /usr/local/bin/npm
              Raspbian v12.
              Would reinstalling node.js and npm be a good idea? This environment is new to me and always feels so cumbersome.
              Thanks for your help BTW.
                @meshuggahn i have no idea, this directory /run/usr, seems to be related to flatpack, but i have not seen nodejs/npm in flatpack packages
