    how to revert to HTTP
    6 Posts 2 Posters 347 Views 2 Watching
      sdetweil @travishardiman
      @travishardiman address already in use means you have another instance of MagicMirror running already
      Do you use pm2 to auto launch MagicMirror at boot
      Do
      pm2 status
      • T Offline
        travishardiman @sdetweil
        @sdetweil I manually stopped the bottom three because they were logging so many errors:
        pi@smartmirror2024:~ $ pm2 status
        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
        │ 0  │ MagicMirror        │ fork     │ 3    │ online    │ 0%       │ 2.9mb    │
        │ 1  │ mmpm.api           │ fork     │ 2    │ online    │ 0%       │ 27.2mb   │
        │ 2  │ mmpm.log-server    │ fork     │ 818  │ stopped   │ 0%       │ 0b       │
        │ 3  │ mmpm.repeater      │ fork     │ 818  │ stopped   │ 0%       │ 0b       │
        │ 4  │ mmpm.ui            │ fork     │ 150  │ stopped   │ 0%       │ 0b       │
          @travishardiman the column in the status output between
          Mode and status is the restart count column
          So 800+ is a bad thing
          • T Offline
            @sdetweil after restarting the whole pi, all the processes in pm2 seem to be running ok, and I can connect over http again.
            However there’s still some weird stuff in the logs: 😆
            3|mmpm.repeater  | [+] Connection to namespace /MMM-mmpm was rejected
            3|mmpm.repeater  | [+] Connection failed, new attempt in 4.80 seconds
            3|mmpm.repeater  | [+] Connection failed, new attempt in 4.55 seconds
            3|mmpm.repeater  | [+] Engine.IO connection dropped
            3|mmpm.repeater  | [+] Engine.IO connection established
            3|mmpm.repeater  | [+] Connection failed, new attempt in 5.47 seconds
            Are these anything that I should worry about?
              @travishardiman sorry I do not know
