    Version 2.33 - module 'weather' - openweathermap and 'One Call by Call' plan
    3 Posts 2 Posters 465 Views 2 Watching
      Mr.Sponti
      Currently I migrate from Magicmirror v2.26.0 to v2.33.0. One issue , the weather module does not start. The module provide me from the provider openweathermap the message:
       {"cod":401, "message": "Please note that using One Call 3.0 requires a separate subscription to the One Call by Call plan. Learn more here https://openweathermap.org/price. If you have a valid subscription to the One Call by Call plan, but still receive this error, then please see https://openweathermap.org/faq#error401 for more info."}
      I don’t have a supscription for the ‘One Call by Call’ plan. But, if I copy the weather module (complete directory) from MM v2.26 to v2.33 I get the forecast weather data from openweathermap without any difficulty and everything is working fine. So there must be a modification in the weather module which leads to the described issue.
      For the moment I’ve a workaround by overriting the wether module with the old version, but it would be nice and helpful if an expert could do a deeper analysis for the cause and understanding of the issue.
      Thanks!
      Here is my configuration for the module:
      			module: 'weather',
      			position: 'top_right',
      			header: 'Wetter Vorhersage für ',
      				type: "forecast",
      				tableClass: 'small',
      				locationID: "2879315",
      				apiKey: "2xxxxxxxxx...xxxxxxxxxd",		//apiKey from http://www.openweathermap.org
      				tempUnits: "metric",
      				roundTemp: true,
      				onlyTemp: true,
      				colored: true,
      				maxNumberOfDays: 4,
      				ignoreToday: true,
      				updateInterval: 3600000,					// every hour
      				initialLoadDelay: 3000,
        sdetweil @Mr.Sponti
        @Mr.Sponti see
        https://forum.magicmirror.builders/post/122915
          Mr.Sponti
          Ok, my fault, thanks a lot!
