    Problem of running MMM-Podcast and MMM-Button
    13 Posts 2 Posters 8.1k Views 2 Watching
    • A
      alex84
      in the config.js there is a missing , behind buttonPIN: ‘5’
      H 1 Reply Last reply
      • H
        hirsnmirsn @alex84
        @alex84 if i had the , behind the buttonPIN:5 ther is always the Black screen
        • A
          alex84
          there is missing a comma
          • H
            hirsnmirsn @alex84
            @alex84 yes
               			module: 'MMM-Button',
            			//https://github.com/PtrBld/MMM-Button
            			//https://developer.microsoft.com/de-de/windows/iot/win10/samples/PushButton.htm
            			//pin GIPO 5 und Ground
            			buttonPIN: '5',
            but i have always the Black screen.
            • A
              alex84
              Change into the MMM-Button folder and execute the following commands
              sudo npm install --save-dev electron-rebuild
              the
              ./node_modules/.bin/electron-rebuild
              • H
                hirsnmirsn @alex84
                @alex84 Thank You,
                Now i have no mor Black Screen, but the Button dont work.
                I have a Pyton Script, this works.
                #Tagesschau.py
                import RPi.GPIO as GPIO
                import os
                import sys
                from subprocess import Popen
                GPIO.setmode(GPIO.BCM)
                GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                movie1 = (“http://media.tagesschau.de/video/100s/2017/0504/TV-100s-1840.webm.h264.mp4”)
                last_state1 = True
                last_state2 = True
                input_state1 = True
                input_state2 = True
                quit_video = True
                player = False
                while True:
                #Read states of inputs
                input_state1 = GPIO.input(5)
                #If GPIO(5) is shorted to Ground
                if input_state1 != last_state1:
                    if (player and not input_state1):
                        os.system('killall omxplayer')
                        omxc = Popen(['omxplayer', movie1])
                        player = True
                    elif not input_state1:
                        player = True
                #If omxplayer is running and GIOP(5) are not shorted to Ground
                elif (player and input_state1 and input_state2):
                    player = False
                #Set last_input states
                last_state1 = input_state1
                Has anybody a working config and button config that he can post?
                • A
                  alex84
                  I will you later Post my config of the button and my config as well as the config of the podcast. I’m on the road. :)
                  • H
                    hirsnmirsn @alex84
                    @alex84 Thank You :ok_hand_tone3:
                    • A
                      alex84
                      Hello hirsnmirsn
                      sorry for the late reply
                      This is in my Config.js
                      module: “MMM-Podcast”
                      module: “MMM-Button”,
                      and last but not least the MMM-Button.js
                      /* global Module */
                      /* Magic Mirror
                      • Module: MMM-Button
                      • MIT Licensed.
                      Module.register(‘MMM-Button’,{
                      requiresVersion: “2.1.0”,
                      defaults: {
                      buttonPIN: 5,
                      //time in miliseconds before another button click is recognized
                      clickDelay: 500,
                      // Override socket notification handler.
                      if (notification === “BUTTON_PRESSED”){
                      this.sendNotification(notification, payload)
                      start: function() {
                      this.sendSocketNotification(‘BUTTON_CONFIG’, this.config);
                      Log.info('Starting module: ’ + this.name);
                      Make a reboot after Change your config.js
                      The only difference I can see in the files is that you tried to load another Solution (so it stands in your Config.js)
                      Feedurl: ‘http://www.tagesschau.de/export/video-podcast/webm/tagesschau-in-100-sekunden/’
                      I have tried it and with me everything runs without problems.
                      • H
                        hirsnmirsn @alex84
                        @alex84 Great Great Great!!!
                        IT WORK`s
                        Thank you
                        • A
                          alex84
                          I’m glad it works. have fun with it. I am glad that I could help
