    Help with showing todoist tasks?
    11 Posts 4 Posters 8.7k Views 3 Watching
      d3r @devtech8
      @devtech8 Everything else seem fine.
        barnosch
        put your lists in
        like this:
        lists: ["2163440886", "2162058078"]
        For troubleshooting, just use one list, if that works then, add the second.
          devtech8 @barnosch
          @barnosch and @d3r - something seems messed up and nothing is going right with this. Tried quite a few variances.
          For some reason, I had it as lists: but I see in the repo for the project that it lists as projects:. So toyed around between the both of them with 1, 2, and 3 projects and creating test tasks. The config says the “projects” look a certain way in the URL with the number being after “%2F”. So in my case for 1 project, this screenshot:
          So now my code in the config should be:
          	module: 'MMM-Todoist',
          	position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
          	header: 'Todoist test', // This is optional
          	config: { // See 'Configuration options' for more information.
          		  accessToken: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
          		maximumEntries: 60,
          		interval: 60,
          		lists: ["2162058078"],
          		fade: false
          I am using the correct API key as noted from a previous response.
          If I look via dev tools at the page, here is a snapshot:
          But still, the best I can get is just the title showing up. Further thoughts please?
          Thanks much.
            barnosch
            This one works for me.
            		position: 'top_left',
            		header: "To Do",
                      		accessToken: 'blablablae0fa5611c30blablablablablabla',
            			maximumEntries: 20,
            			interval: 600,
            			lists: [ "2157759361" ],
            			fade: false,
            the %2F must be subtracted, correct.
            Did you install all the dependencies of the module with
            “npm install” within the “modules/MMM-todoist” folder ?
              barnosch
              something else i mentioned.
              As i remember, there was some issues, Todoist was not showing something, like in your case.
              I never had the problems and i am on an very old version (jan 9)
              pi@pi3:~/MagicMirror/modules/MMM-Todoist $ git show
              commit 155ffe4d49bd8af59ab8bb0736c3ad756c0515d6
              (btw. not sure, if this is correct, like i did it, to see the installed version)
              Maybe @cbrooker has a idea for your problem.
                d3r
                @devtech8 Just remembered there was something else too.
                Did you take a look at this?
                https://github.com/cbrooker/MMM-Todoist/issues/16
                  devtech8
                  That issue @d3r mentioned was the problem. It now displays just fine. Thanks for the help!
                  • zdenekZ Offline
                    zdenek
                    dears, can u plz provide me step-by-step how to get token? I’ve ID and Secret, but no idea what to do now…
                    thanks, Zdeněk
