MMM-Newsfeed is only working for a day
8 Posts 2 Posters 2.2k Views 2 Watching
    Squirrel
    After a day one of my rss newsfeedmodul is no more working. When i restart the magicmirror then it works fine. Does somebody have the same trouble?
      Medo
      Hi…
      I had exactly the same issues.
      I changed from a .html rss feed to an .xml feed and all refreshing-problems were gone.
      Hope this helps…
        Squirrel
        @Medo Unfortunately i use already a xml feed. Is this the only thing you changed?
        module: 'newsfeed',
        position: 'bottom_bar',
        		feeds: [
        				title: "Zitat des Tages",
        				url: "http://zitate.net/rss/500100303/zitate.xml"
        				//url: "http://zitate-online.de/zitatdestages.xml"
        				showSourceTitle: false,
        				showPublishDate: false,
        				reloadInterval: 300000,
          Medo
          I remember that a .xml feed worked for me. But some months i changed here and there…
          I checked my current config and i use this feed:
          url: “http://www.tagesschau.de/xml/rss2/”
          This feed works for months now.
            Squirrel
            hmm i use a second one from 20minuten.ch and this one is working very well. Maybe i have to look for another Quotation-Feed… But i cant understand why this one is only workling when i restart my mirror… This is strange… i can see not even the quotation from the last day. After +/- 24h hours i have ony “Loading” on the screen…
            M 1 Reply Last reply Feb 11, 2018, 4:30 PM Reply Quote 0
              Medo @Squirrel
              @Squirrel
              Yep, exactly what i experienced. One feed works, the other not.
              I surrendered (after many attempts to fix that problem) and searched for a working feed. After that, i had no more problems with the feed. Maybe a coding bug.
                Medo
                I still do have a problem with an not updating calender…
                And if you want to investigate further, you can try this:
                https://forum.magicmirror.builders/topic/4682/not-updating-after-network-lost/4
                Maybe my wifi drops out so some modules cant be updated…
                I will give it a try as soon as i will find time for that kind of “fun” ;-)
                M 1 Reply Last reply Feb 26, 2018, 2:18 PM Reply Quote 0
                  Medo @Medo
                  @all
                  Seems like i found the problem why some modules stopped working.
                  I revisited my MM configuration and noticed i had lost my “keep WiFi active” configuration…
                  I opened /etc/network/interfaces and put in the missing “wireless-power off”.
                  More infos here: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 (see chapter “Installing MagicMirror - Step 4”)
