    NPM install is giving Error.
    18 Posts 11 Posters 29.5k Views 11 Watching
      alessandroiacovella
      same with me :pouting_face:
        merceg100
        Same here:
        Same here:
        pi@raspberrypi:~/MagicMirror $ npm install
        (node:4024) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm ERR! Error: Method Not Allowed
        npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
        npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
        npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
        npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
        npm ERR! If you need help, you may report this entire log,
        npm ERR! including the npm and node versions, at:
        npm ERR! http://github.com/npm/npm/issues
        npm ERR! System Linux 4.14.52-v7+
        npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
        npm ERR! cwd /home/pi/MagicMirror
        npm ERR! node -v v8.11.1
        npm ERR! npm -v 1.4.21
        npm ERR! code E405
        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
        electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
        node ./download-chromedriver.js
        npm ERR! fetch failed https://registry.npmjs.org/lodash.isobject/-/lodash.isobject-3.0.2.tgz
        npm WARN engine rxjs@5.5.11: wanted: {“npm”:“>=2.0.0”} (current: {“node”:“8.11.1”,“npm”:“1.4.21”})
        npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
        npm ERR! fetch failed https://registry.npmjs.org/nomnom/-/nomnom-1.8.1.tgz
        npm ERR!
        npm ERR! Additional logging details can be found in:
        npm ERR! /home/pi/MagicMirror/npm-debug.log
        npm ERR! not ok code 0
        • N Offline
          NoNameRo @merceg100
          @postremalone @alessandroiacovella @merceg100
          Upgrade npm with
          npm install -g npm@latest
            alessandroiacovella
            What command do you type to upgrade npm?
              merceg100 @NoNameRo
              @nonamero said in NPM install is giving Error.:
              Upgrade npm with
              Tried it… doesn’t help either…
                postremalone
                Bump… Anyone help please.
                  merceg100
                  @alessandroiacovella said in NPM install is giving Error.:
                  After I installed MM using this command:
                  git clone https://github.com/MichMich/MagicMirror
                  then I ran:
                  sudo apt-get install npm
                  afterwards:
                  cd MagicMirror
                  npm install
                  Then I tried
                  but it didnt work also.
                  I am running latest updated Raspbian on RPi 3 b+
                  • N Offline
                    NoNameRo @merceg100
                    @merceg100
                    please try the following
                    sudo apt-get remove nodejs nodejs-legacy nodered
                    after that
                    curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
                    sudo apt-get install -y nodejs
                    after that enter in the repository with
                    cd MagicMirror
                    then install and run the app with
                    npm install && npm start
                    in case of errors please post here.
                    why do not you use the automatic installation for the RPi 3 b +
                    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                    D D 2 Replies Last reply Reply Quote 0
                    • F Offline
                      fire1ce
                      @nonamero
                      won’t install npm. getting command not found: npm
                      • N Offline
                        NoNameRo @fire1ce
                        @fire1ce
                        try
                        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
