    Error on starting MM2: module not present
    22 Posts 2 Posters 10.2k Views 2 Watching
      MWel1977 @sdetweil
      @sdetweil is npm then the compiler?
      If so how can I recompile the mmm-usonic module so it works with my current Node.js version?
      Is there somewere documentation on how this npm works and how all the modules are tide in it?
        npm --help should give you the options…
        from MM,
        npm rebuild MMM-usonic
          MWel1977 @sdetweil
          @sdetweil And do I have to be in a specific folder for this command (in the npm home folder or the mmm-usonic for instance)?
          Or can I just type it in the terminal from the start (/Home/Pi/)?
          That is what I still don’t quite get. What command must be used in what (folder) location.
          But I’ll try that command tonight at home.
          (I have my 3B+ with me here at work (that has the “working” MM2 on it. At home I have the Pi 3A+ attached to the 7" touchscreen and has the “test enviroment” of my MM2 on it. So when something works on the 3A+ (and I know how to do it right) I can do it first time right on the 3B+.:smiling_face_with_open_mouth_smiling_eyes: )
            sdetweil @MWel1977
            @mwel1977 well, you can be in many different places…
            npm install (no other parms) will install the module in the current folder, so this could be MagicMirror (for all using modules), OR it could be in the MMM-Swipe folder only (then only available for MMM-Swipe)
            or you can add -g parm, and regardless of the current folder, it is added to the system wide node_modules, so it is available for any/all applications that want/need to use it.
              MWel1977 @sdetweil
              @sdetweil may I ask you were you think that mmm-usonic module should be install in order for it to work with the mmm-swipe module?
              Reading what your telling me I’m starting to think it should be installed in the MMM-Swipe folder. However the error notification shows that it found the mmm-usonic module only it’s compiled with a wrong version.
              I’ll try you suggestion “npm rebuild MMM-usonic” tonight and from the folder “/Home/Pi/” and see what happens (If I understand you correctly I can also use just “npm rebuild” when I’m in the folder “/Home/Pi/node_modules/mmm-usonic/”).
              And I think I’ll start reading this after I’ve done that: https://docs.npmjs.com/ :grinning_face_with_smiling_eyes:
              Hope I’ll know more about npm afterwards.
                where was it installed (check the MM/node-modules folder and the MM/modules/MMM-Swipe/node-modules folder…
                rebuild where found…
                  MWel1977 @sdetweil
                  Oh…crap! :flushed_face: I have a node_modules folder under Home/Pi
                  not under Home/Pi/MagicMirror.
                  Think I’ll format my micro SD card and start over. This time when I install something for the MM I’ll do it from the directory Home/Pi/MagicMirror.
                  Don’t think I can just “move” the content of the Home/Pi/node_modules to the MagicMirror folder can I? :weary_face:
                    sdetweil @MWel1977
                    @mwel1977 just erase the one in /home/pi (rm -rf node_modules) and then start from the MM folder,
                    then erase node_modules, then do npm install, then switch to MMM-Swipe and do npm install,
                    then npm rebuild MMM-usonic
                    no need to wipe and start over…
                      MWel1977 @sdetweil
                      @sdetweil If I understand you right:
                      #1 remove node_modules in “Home/Pi” and in “Home/Pi/MagicMirror” with command “rm -rf node_modules”
                      #2 re-install npm in the folder “Home/Pi/MagicMirror” and in “Home/Pi/MagicMirror/MMM-Swipe”
                      #3 then re-install the module mmm-usonic in the folder “Home/Pi/MagicMirror/MMM-Swipe”
                      #4 then rebuild the usonic module with “npm rebuild mmm-usonic”
                      I have doubt on where to install step 3. Should it go in the folder from the MagicMirror or from de module MMM-Swipe? Because I delete the module mmm-usonic with step 1. And I don’t know if this will be installed on re-installing the module MMM-Swipe.
                      But I’ll check that first thing tonight (if there is a module mmm-usonic being installed with MMM-Swipe). I think it should be installed with it as a dependency from MMM-Swipe.
                        sdetweil @MWel1977
                        @mwel1977 step 3, in the modules/MMM-Swipe folder,
                        npm install MMM-usonic
                        Then same folder,
                        M 2 Replies Last reply Reply Quote 1
                          MWel1977 @sdetweil
                          Did it tonight. couldn’t make it yesterday.
                          So…did as we sad like above…yet it didn’t work.
                          This time something with electron. Here’s the terminal “output”:
                          pi@Mirror:~/MagicMirror/modules/MMM-Swipe $ npm install
                          npm WARN deprecated math-statistics@1.2.0: THIS PROJECT IS NO LONGER MAINTAINED by clebert
                          npm WARN deprecated expressive-assertion@1.5.1: THIS PROJECT IS NO LONGER MAINTAINED by clebert
                          npm WARN deprecated typesystem@5.0.0: THIS PROJECT IS NO LONGER MAINTAINED by clebert
                          > mmm-gpio@3.0.2 install /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio
                          > node-gyp configure build
                          make: Map '/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/build' wordt binnengegaan
                            CXX(target) Release/obj.target/gpio/src/gpio.o
                            CXX(target) Release/obj.target/gpio/src/node_gpio.o
                            SOLINK_MODULE(target) Release/obj.target/gpio.node
                            COPY Release/gpio.node
                          make: Map '/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-gpio/build' wordt verlaten
                          > mmm-usonic@2.5.3 install /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic
                          make: Map '/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/build' wordt binnengegaan
                            CXX(target) Release/obj.target/usonic/src/clock.o
                            CXX(target) Release/obj.target/usonic/../mmm-gpio/src/gpio.o
                            CXX(target) Release/obj.target/usonic/src/node_usonic.o
                            SOLINK_MODULE(target) Release/obj.target/usonic.node
                            COPY Release/usonic.node
                          make: Map '/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/build' wordt verlaten
                          > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-Swipe
                          > electron-rebuild -e ../../node_modules/electron-prebuilt
                          An unhandled error occurred inside electron-rebuild
                          Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                          Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:80:19)
                              at Generator.next (<anonymous>)
                              at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:8:71
                              at new Promise (<anonymous>)
                              at __awaiter (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:4:12)
                              at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:69:8
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:145:4)
                              at Module._compile (internal/modules/cjs/loader.js:654:30)
                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                              at Module.load (internal/modules/cjs/loader.js:566:32)
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 255
                          npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                          npm ERR! Exit status 255
                          npm ERR!
                          npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script.
                          npm ERR!     /home/pi/.npm/_logs/2019-01-15T19_01_22_044Z-debug.log
                          Can’t I just remove the MMM-Swipe module and reinstall it?
                            MWel1977 @sdetweil
                            Or can I better start clean and remove npm completely sudo npm uninstall npm -g and then reinstall?
                            I mean repearing all this could take longer than just simply uninstall and reinstall npm, MM2 and the few modules I have on this sd card. I just need the config.js file the store on a usb drive for when I’m done.
                            Or you think repearing that electron issue is a quick fix?:smiling_face_with_open_mouth_cold_sweat: :smiling_face_with_open_mouth_cold_sweat:
                              sdetweil @MWel1977
                              @mwel1977 said in Error on starting MM2: module not present:
                              sure… but u said that didn’t work before…
                              the package.json in MMM-Swipe is looking for electron version 1.2.1, very old…
                              I would edit the file before running npm install in the MMM-Swipe folder and chaneg the version to match
                              whatever electron verison is installed already…
                              MM/node_modules/electron/package.json
                              “version”: “2.0.13”
                              the MMM-Swipe package.json to
                              change
                              devDependencies": {
                                  "electron-rebuild": "^1.2.1"
                              to
                              devDependencies": {
                                  "electron-rebuild": "^x.y.z"  === the electron version number above
                                MWel1977 @sdetweil
                                I think I’ll just start over again with a reimage of the sd card.:persevering_face:
                                I’ve checked the package.json file in the electron folder and it showed version 2.0.16
                                So I entered that number at the bottom of the package.json file in the MMM-Swipe folder and run npm install again in the Swipe folder. Yet it gave me:
                                npm ERR! code ETARGET
                                npm ERR! notarget No matching version found for electron-rebuild@^2.0.16
                                npm ERR! notarget In most cases you or one of your dependencies are requesting
                                npm ERR! notarget a package version that doesn't exist.
                                npm ERR! notarget
                                npm ERR! notarget It was specified as a dependency of 'MMM-Swipe'
                                npm ERR! notarget
                                npm ERR!     /home/pi/.npm/_logs/2019-01-15T22_09_44_953Z-debug.log
                                Thanks for helping me out so far.
                                How do you know al this stuff? How long are you already doing this?
                                Hope I’ll get that smart one day. :grinning_face:
