    Default Calendar module // request to show events only if start date > today + 2 days
    10 Posts 3 Posters 3.7k Views 4 Watching
      bolish
      @ganget
      no problem. thanks for the idea.
      I was thinking about modifying the module code to change “today’s” date into “today’s date +2” but can’t yet figure out how too.
        sdetweil @bolish
        @bolish
        the existing code is.
        	if (event.startDate >= new Date()) {
        and ideas on how to add days to today or whatever
        https://stackoverflow.com/questions/3818193/how-to-add-number-of-days-to-todays-date
          bolish
          Thanks, I will give it a try this evening and keep you guys posted.
            bolish
            Hi again, I just tried by modifying the createEventList “today” and “now” variable, but it didn’t work…
            createEventList: function () {
            		var events = [];
            		var someDate = new Date();
            		var numberOfDaysToAdd = 6;
            		someDate.setDate(someDate.getDate() + numberOfDaysToAdd);
            		var today = moment(someDate).startOf("day");
            		var now = someDate;
            		for (var c in this.calendarData) {
              sdetweil @bolish
              @bolish close…
              the existing loop takes ALL events, just checking to see if each event is TODAY (sets a flag)
              to eliminate them you need one more test (in addition to the rest of your code above)
              	//var today = moment().startOf("day");
              			var calendar = this.calendarData[c];
              			for (var e in calendar) {
              				var event = calendar[e];
                                               // if event happens further away than x number of days (6 in this sample)
              				if(event.startDate>= today) {    < ------
              					if(this.config.hidePrivate) {
              						if(event.class === "PRIVATE") {
              							  // do not add the current event, skip it
              							  continue;
              					event.url = c;
              					event.today = event.startDate >= today && event.startDate < (today + 24 * 60 * 60 * 1000);
              					events.push(event);
                bolish
                Works like a charm.
                Thank you very much, I’ve learnt something thanks to you and appreciated your support for debug.
                See you around.
