    some modules are not showing on screen
    23 Posts 5 Posters 9.0k Views 5 Watching
      A Former User
      oh lord… I quess I have something…
      WTF.
      I quess it was my mistake… Was it?
      Some modules are in /MagicMirror/node_modules/
      and some are in /MagicMirror/modules
        sdetweil @Guest
        @stephen node_modules are the ones download by install in support of the mirror… all good
        modules are the add ons to the MagicMirror
          A Former User
          Maybe it has something to do with the
          npm install
          sometimes I had to run (as discribed at the mod-pages)?
          I’ll try to pull the modules in the right folder and give it a try
            sdetweil @Guest
            @stephen no… don’t change anything… npm install built the node_modules folder… it is ok…
              A Former User
              Hell…thats it!
              I’ve reinstalled the “not-working” / not showing modules INTO the /modules folder and it simply works!
              Have a big thanks @sdetweil !
              Its not always a filesystem-problem, sometimes the problem is right in front of the keyboard :D
                sdetweil @Guest
                @stephen cool
                  sdetweil @Guest
                  @stephen sorry, I misread your 1st post… I took it to mean it HAD been working and all of a sudden it was not…
                  got to learn to read more carefully!
                  can u mark your problem resolved?
                  • G Offline
                    ganget
                    @stephen You can start MM with developer mode. This can be done by using the cmd shell inside the MagicMirror folder and run the following command:
                    npm start dev
                    or when you’re MM is already running use the shortcut ctrl+shift+I. This article from @Mykle1 gives you all the info you need.
                    All of this can be done will using VNC. (I use VNC as well :smiling_face_with_smiling_eyes: )
                    Good luck!
                      showbizkid
                      I maybe wrong but should there be quote marks around any words that are in orange. My mirror has no quotes around any of those words. That’s what stood out to me.
                        showbizkid
                        https://jshint.com/ This site has helped me. Just delete the code that is there and copy and paste your entire code to see your errors .
