    I'm tired with Magic Mirror 6 update
    8 Posts 2 Posters 2.3k Views 2 Watching
      Smotx
      So i have try
      pi@raspmagicmirror1:~/MagicMirror $ npm install electron
      and now :
      > electron@2.0.18 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      internal/modules/cjs/loader.js:550
          throw err;
      Error: Cannot find module '../dotjs/validate'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
          at Function.Module._load (internal/modules/cjs/loader.js:475:25)
          at Module.require (internal/modules/cjs/loader.js:598:17)
          at require (internal/modules/cjs/helpers.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/ajv/lib/compile/index.js:8:25)
          at Module._compile (internal/modules/cjs/loader.js:654:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron@2.0.18 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@2.0.18 postinstall script.
      npm ERR!     /home/pi/.npm/_logs/2019-03-09T16_57_50_712Z-debug.log
        Smotx
        LOOOOL.
        Sooo i try
        pi@raspmagicmirror1:~/MagicMirror $ npm install stylelint@^9.0.0
        and result… tada … !
        > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
            throw err;
        npm ERR! errno 1
        npm ERR! electron@2.0.16 postinstall: `node install.js`
        npm ERR!
        npm ERR! Failed at the electron@2.0.16 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2019-03-09T17_05_00_446Z-debug.log
          Smotx
          So :
          I have rename /MagicMirror/ to /BackMM/
          I have launch a new fresh install of MM 2.6
          Copy /modules/ , /config/ & /css/ from /BackMM/
          and launch MM
          It’s ok
          if it helps someone.
          *I have a little error, but i don’t know why.
          Starting node_helper.js for MMM-TPLink.
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-AlexaOnOff
          Module helper started for MMM-AlexaOnOff
          Launching application.
          **ERROR! Could not find main module js file for modules
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections tha                                               t are not handled will terminate the Node.js process with a non-zero exit code.
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 8): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 9): TypeError: Cannot read property                                                'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 10): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 11): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 12): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 13): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 14): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 15): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 16): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 17): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 18): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 19): TypeError: Cannot read propert                                               y 'refs' of undefined
          (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 20): TypeError: Cannot read propert                                               y 'refs' of undefined**
          Sat Mar 09 2019 18:49:08 GMT+0100 (CET): Triggering Xiaomi Gateway connect
          Create new news fetcher for url: https://www.francetvinfo.fr/monde.rss - Interval: 300000
          starting internet monitor node helper
          FREEBOX: "CONNECT" [object Object]
            sdetweil @Smotx
            @Smotx typically you also must npm install in each module folder if they have a package.json file so that their components are at the same level
            I would start with each module over the defaults and comment them out, and back in one by one
              Smotx
              @sdetweil said in I'm tired with Magic Mirror 6 update:
              Ok, i’ll try
