    Getting API data in table
    7 Posts 3 Posters 2.8k Views 3 Watching
    • htilburgsH Offline
      htilburgs
      I get data through an API, lets say:
      alarm: "0"
      d0neerslag: "4"
      d0tmax: "12"
      d0tmin: "5"
      Currently I’m making a table, row and cells in the getDOM function to display the data:
      var TemperatuurRow = document.createElement("tr");
      TemperatuurRow.className = "temperatuur-row";
      var TempTextCell = document.createElement("td");
      TempTextCell.className = "small";
      TempTextCell.innerHTML = "Neerslag";
      TemperatuurRow.appendChild(TempTextCell);
      table.appendChild(TemperatuurRow);
      var TempDataCell = document.createElement("td");
      TempDataCell.className = "small fas fa-thermometer-half";
      TempDataCell.innerHTML = "  " + MWB.d0neerslag;
      TemperatuurRow.appendChild(TempDataCell);
      return table;
      This is a lot of type-work. I was thinking isn’t there a better way?
      I was thinking of creating a table with the names and combine this with the results from the API. Can this be done? And how?
      (still trying to learn JS, but not afraid to ask) :smiling_face:
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs you could make a routine to do each element.
        Using replace or regular expression is just as much work in my opinion
          htilburgs
          @sdetweil, so what you’re saying is continu as I’m started with table, row, cells manual?
          I was hoping something in the next style would work.
             for (i = 0; i < this.MWB.length; i++) {
          	var MWB = this.MWB[i];
          and combining this with the text of the result. But I can’t figure it out.
            sdetweil @htilburgs
            @htilburgs well, thinking something like this , same work, less actual code, more readable
            // create elements... take an object in as parms, makes it easier to understand
              // what is supplied vs not
              newElement: function(parms_object ){
              var e=null;
              switch(parms_object.type){
                 case 'table':
                    e=document.createElement('table');
                 break;
                 case 'row':
                    e=document.createElement('tr');
                 break;
                 case 'column':
                    e=document.createElement('td');
                 break;
              if(parms_object.classname !== undefined)
                 e.className=parms_object.classname;
              if (parms_object.value !== undefined)
                 e.innerHTML = parms_object.value
              if(parms_object.parent !== undefined)
                 (parms_object.parent).appendChild(e)
              return e;
            getDom: function(){
              var table = this.newElement({type:'table'}) // note here, just type specified, to test code above
              // repeat the rows/columns block as needed  maybe in a loop as well..
              // get the list of items in the object
              for(item_name of Object.keys(this.MBW)){  // i think this returns keys in position order, not alphabetical
                var row=this.newElement({type:"row",classname:"temperatuur-row",parent:table})
                // add a column for the data item name
                this.newElement({parent:row, type:"column",classname:"small",value:item_name}) // parms in any order
                // get the data for the item
                let item_value= this.MBW[item_name]
                this.newElement({type:"column",classname:"small",value:item_value,parent:row})
              wrapper.appendChild(table)
              return wrapper
            htilburgsH 1 Reply Last reply Reply Quote 0
              htilburgs @sdetweil
              @sdetweil Thank you for the reply. I’m going to play with it and see which kind suited me the best.
                sdetweil @htilburgs
                @htilburgs by using a routine to do the element create->parent.append() you reuse one copy of the code, instead of the tedious copy/paste/edit/fix cycle…
                some people use div/span/span/span instead of table… this routine will work the same with two case statements added, so you can use div and span instead of tr/td
                  bachoo786 @sdetweil
                  @sdetweil hi did you make a table then? where did you put your java code? i.e. which file?
