    Calendar issue with 2.7.1
    12 Posts 3 Posters 4.6k Views 4 Watching
      drfukc
      Hi Dommer,
      Quite similar with me. I have a fresh Raspberry installation on my Pi-3B, the only additional packages installed are vsftpd (FTP-tool) and xrdp (RDP-server to allow Windows Remote Desktop Connections). On this fresh installation I have installed MagicMirror² and default Weather- and News app are working fine receiving live data.
      For some reason the calendar app does not work and I get the same error message for the calendar module as you in my log-file:
      ./home/pi/.pm2/logs/MagicMirror-error.log
      ATTENTION: default value of option force_s3tc_enable overridden by environment.
      TypeError: Cannot read property 'length' of undefined
          at eventDate (/home/pi/MagicMirror/modules/default/**calendar/calendarfetcher.js:69:25)
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:90:22
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
          at Request.emit (events.js:182:13)
          at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
          at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
          at Object.onceWrapper (events.js:273:13)
          at IncomingMessage.emit (events.js:187:15)
      I reinstalled from scratch on another SD-card with the same result.
        sdetweil @Dommer
        @Dommer said in Calendar issue with 2.7.1:
        there is an event which does not have a start date and time. i looked thru changes to the calendarfetcher code, and cannot see any change to this line of code since before 2017.
        data={"type":"VEVENT","params":[],"uid":"42271","dtstamp":"20190414T114129Z","summary":"District Closed","class":"PUBLIC","status":"CONFIRMED","priority":"0","sequence":"0","duration":"P1D","last-modified":"20180523T131717Z","transparency":"OPAQUE"}
        raw data from ical
        BEGIN:VEVENT
        UID:42271
        DTSTAMP:20190414T112505Z
        SUMMARY:District Closed
        CLASS:PUBLIC
        STATUS:CONFIRMED
        PRIORITY:0
        SEQUENCE:0
        DTSTART:20190419
        DURATION:P1D
        LAST-MODIFIED:20180523T131717Z
        TRANSP:OPAQUE
        END:VEVENT
          sdetweil @drfukc
          @drfukc this is the same problem as for @Dommer …
          if u can send me your calendar entry url, I can look at it to see which event is causing this problem…
          or u can uncomment the one line in mm/modules/default/calendar/calendarfetcher.js, line
          				if (event.type === "VEVENT") {
                   // console.log("have event title="+event.summary);
          and restart the mirror
          you will see the event summary in the pm2 log
            drfukc
            Hi Sam,
            the calendar entry I use for testing is the standard URL:
            As advised by you I searched up-and-down my calendarfetcher.js in:
            I can find the following string: if (event.type === “VEVENT”) {
            But I cannot even find substring to uncomment such like this: console.log("have or event title or
            Hence there seems to be nothing to uncomment
            I rather believe my issue has something to do with to many Electron instances that kill several moduls.
            Maybe you have an idea for this:
            1. I boot up my raspberry 3b
            2. Execute ‘ps -a’ to check the running processes
            3. ‘ps -a’ returns ‘ps’ as the only running processes
            4. launching the mirror: ‘npm start &’
            5. the console tells me uncaught exception since EADDRINUSE is already in use:
            magicmirror@2.7.1 start /home/pi/MagicMirror
            sh run-start.sh
            Starting MagicMirror: v2.7.1
            Loading config ...
            Loading module helpers ...
            All module helpers loaded.
            Server started ...
            Starting module: newsfeed
            { Error: listen EADDRINUSE 127.0.0.1:8080
                at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                at listenInCluster (net.js:1378:12)
                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
              errno: 'EADDRINUSE',
              code: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8080 }
            1. Now I recheck my running processes and see *four instances of Electron. According to another thread it looks like I run two instances of MagicMirror in parallel, that have a conflict with each other and causing this EADDRINUSE message:
            PID TTY          TIME CMD
             1176 pts/0    00:00:01 npm
             1187 pts/0    00:00:00 sh
             1188 pts/0    00:00:00 sh
             1189 pts/0    00:00:00 node
             1196 pts/0    00:00:30 electron
             1198 pts/0    00:00:00 electron
             1236 pts/0    00:00:00 electron
             1238 pts/0    00:00:15 electron
             1305 pts/1    00:00:00 ps
            1. Checking PM2 by ‘pm2 list’ gives me only one instance:
            pi@raspberrypi:~ $ pm2 list
            ¦ Name        ¦ id ¦ mode ¦ status ¦ ? ¦ cpu ¦ memory   ¦
            ¦ MagicMirror ¦ 0  ¦ fork ¦ online ¦ 0 ¦ 0%  ¦ 2.5 MB   ¦
            1. For more details I try pm2 show 0
            pi@raspberrypi:~ $ pm2 show 0
             Describing process with id 0 - name MagicMirror
            ¦ status            ¦ online                                   ¦
            ¦ name              ¦ MagicMirror                              ¦
            ¦ version           ¦ 2.7.1                                    ¦
            ¦ restarts          ¦ 0                                        ¦
            ¦ uptime            ¦ 16m                                      ¦
            ¦ script path       ¦ /home/pi/MagicMirror/installers/mm.sh    ¦
            ¦ script args       ¦ N/A                                      ¦
            ¦ error log path    ¦ /home/pi/.pm2/logs/MagicMirror-error.log ¦
            ¦ out log path      ¦ /home/pi/.pm2/logs/MagicMirror-out.log   ¦
            ¦ pid path          ¦ /home/pi/.pm2/pids/MagicMirror-0.pid     ¦
            ¦ interpreter       ¦ bash                                     ¦
            ¦ interpreter args  ¦ N/A                                      ¦
            ¦ script id         ¦ 0                                        ¦
            ¦ exec cwd          ¦ /home/pi/MagicMirror                     ¦
            ¦ exec mode         ¦ fork_mode                                ¦
            ¦ node.js version   ¦ N/A                                      ¦
            ¦ node env          ¦ N/A                                      ¦
            ¦ watch & reload    ¦ ?                                        ¦
            ¦ unstable restarts ¦ 0                                        ¦
            ¦ created at        ¦ 2019-04-06T11:57:10.685Z                 ¦
             Revision control metadata
            ¦ revision control ¦ git                                              ¦
            ¦ remote url       ¦ https://github.com/MichMich/MagicMirror.git      ¦
            ¦ repository root  ¦ /home/pi/MagicMirror                             ¦
            ¦ last update      ¦ 2019-04-15T06:53:55.840Z                         ¦
            ¦ revision         ¦ b508a629e8a727358f1b88e3c7df842d14669ec4         ¦
            ¦ comment          ¦ Merge pull request #1632 from MichMich/fix-2.7.1 ¦
            ¦                  ¦ Fix package.json version number.                 ¦
            ¦ branch           ¦ master                                           ¦
            Any ideas?
              sdetweil @drfukc
              @drfukc said in Calendar issue with 2.7.1:
              ok, then something ELSE on your system is using port 8080… maybe a web server?
              change the port number in mm/config/config.js to something else (8081 maybe)
              so, add the second line and then uncomment it… I must have added that fro debugging someone elses problem
                drfukc
                Thanks for your comment.
                First I changed the port as recommended in mm/config/config.js to 8081 and gave it a reboot.
                After reboot and logon I checked the network connections by sudo netstat -lnptu:
                pi@raspberrypi:~ $ sudo netstat -lnptu
                Aktive Internetverbindungen (Nur Server)
                Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      836/electron.js
                tcp6       0      0 :::21                   :::*                    LISTEN      418/vsftpd
                tcp6       0      0 ::1:3350                :::*                    LISTEN      446/xrdp-sesman
                tcp6       0      0 :::3389                 :::*                    LISTEN      461/xrdp
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           318/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           348/dhcpcd
                udp        0      0 0.0.0.0:47216           0.0.0.0:*                           318/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                318/avahi-daemon: r
                udp6       0      0 :::34261                :::*                                318/avahi-daemon: r
                I am surprised to see Electron already listening on port 8081, though I have not started the MagicMirror.
                In the next step I launch Magic Mirror by calling: npm start &
                Unfortunately I see again a EADDRINUSE message (port 8081):
                Server started ...
                { Error: listen EADDRINUSE 127.0.0.1:8081
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  port: 8081 }
                Launching application.
                While the mirror is running I execute again sudo netstat -lnptu and get:
                pi@raspberrypi:~/MagicMirror $ sudo netstat -lnptu
                tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      888/electron.js
                tcp6       0      0 :::21                   :::*                    LISTEN      435/vsftpd
                tcp6       0      0 ::1:3350                :::*                    LISTEN      450/xrdp-sesman
                tcp6       0      0 :::3389                 :::*                    LISTEN      465/xrdp
                udp        0      0 0.0.0.0:42644           0.0.0.0:*                           318/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           354/dhcpcd
                udp6       0      0 :::42148                :::*                                318/avahi-daemon: r
                This is strange. The launch of the mirror npm start & tells me a multiple use of the port 8080 or 8081 (whatever it set in config.js) but netstat -lnptu does not know anything about a duplicate use.
                As advised I also added below line right after if (event.type === “VEVENT”) { in ftp://192.168.178.36/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                Unfortunately the console outcome again is: “EADDRINUSE”
                Starting server on port 8081 ...
                Server started ...
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  port: 8081 }
                I feel a little bit lost … … …
                  sdetweil @drfukc
                  @drfukc is mirror starting on boot with PM2?
                  go to console and do
                  pm2 list
                  is something, get its name and pm2 stop name
                    drfukc
                    Thanks for your advise. After launching the mirror I do a pm2 list with the following result:
                    pi@raspberrypi:~/MagicMirror $ pm2 list
                     Use `pm2 show <id|name>` to get more details about an app
                    With this information I stop the MagicMirror by the following command: pm2 stop 0
                    pi@raspberrypi:~ $ pm2 stop 0
                    [PM2] Applying action stopProcessId on app [0](ids: 0)
                    [PM2] [MagicMirror](0) ?
                    ¦ MagicMirror ¦ 0  ¦ fork ¦ stopped ¦ 0 ¦ 0%  ¦ 0 B    ¦
                    By surprise the running MagicMirror survives and I kill the Electron instance with kill
                    After the MagicMirror instance is terminated I relaunch MagicMirror again with npm start &
                    The funny thing is that the naughty EADDRINUSE message is gone by now, but the calendar is still not working:
                    pi@raspberrypi:~/MagicMirror $ npm start &
                    [2] 1279
                    [1]   Fertig                  npm start
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                    Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                    OK, as said above I have relaunched the mirror by npm start & and try to evaluate what is going on with pm2 list:
                    It’s funny, pm2 list tells me that the Mirror has stopped, while it is still running, but I still do not recieve any Calendar updates.
                    What is wrong here?
                      sdetweil @drfukc
                      @drfukc that calendar,
                      is thru 2018…
                      this one contains thru 2019
                      url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                        drfukc
                        Thanks a lot, - this helped :-) , it is so much easier if things are done right straight from the beginning :-D
                        In addition I also found the root cause for above reported “EADDRINUSE” error.
                        Simple again: I have enabled MagicMirror autostart in /home/pi/MagicMirror/installers/mm.sh, but don’t see it since I use a Remote Desktop connection (RDP) that gives me a different X-Window in comparison to the native Raspberry desktop.
                        Now launching Magic Mirror a second time on a different desktop and the same port causes the issue.
                        Since I disabled MM autostart Magic Mirror boots up without these errors.
                        Maybe I should get back from XRDP and switch to the preinstalled VNC to avoid having multiple desktops.
                        Again, thanks a lot for your support :-)
