    unable to change modules details
    16 Posts 2 Posters 4.3k Views 2 Watching
      sdetweil @yrayapati
      @yrayapati tell us more… what do you want to change, what have you done, what didn’t work…
      show your config
      here on the forum put 3 backtick marks (to the left of the number 1) before and after the info you post from config.js
      • Y Offline
        yrayapati @sdetweil
        Thanks for your reply,
        below are the change that i have made to config.js
                                header: "US Holidays",
                                                        symbol: "calendar-check",
                                                        url: "webcal://www.calendarlabs.com/ical-calender/ics/33/India_Holidays.ics"
          sdetweil @yrayapati
          @yrayapati said in unable to change modules details:
          if u put that in a browser, does it download the ICS file?
          https://www.calendarlabs.com/ical-calender/ics/33/India_Holidays.ics  // does not work  (notice the e in ical-calender
          https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics  // works
          • Y Offline
            yrayapati @sdetweil
            type mistake
            thank you sam
              sdetweil @yrayapati
              @yrayapati is that the only problem?
              • Y Offline
                yrayapati
                @sam below regarding weather
                In the below piece of code they are saying that “unzip the gz file and find your city”
                module: “currentweather”,
                position: “top_right”,
                locationID: “1176734”, //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                appid: “YOUR_OPENWEATHER_API_KEY”
                But in the link i could see two weather related files as:
                –>weather_14.json.gz 14-Mar-2017 12:33 1564623
                –>weather_16.json.gz 05-Apr-2019 11:08 8292321
                I have downloaded “weather_16.json.gz” file and changes details respectively…
                can you correct me if i have done anything worng
                  sdetweil @yrayapati
                  @yrayapati right _14 is from 2 years ago… some cities maybe have been discovered for openweather since then!..
                  and u got your api key, that matches the kind of weather u wanted…
                  • Y Offline
                    yrayapati
                    @sam I followed the steps described in this video and got API key
                      sdetweil @yrayapati
                      @yrayapati are u good now? weather and calendar… anything else?
                      • Y Offline
                        yrayapati @sdetweil
                        @sdetweil first of all I am not able see any weather related details on the screen
