    I'm lost
    7 Posts 2 Posters 2.3k Views 2 Watching
    • T Offline
      Techgator2
      Hello ,
      I’m extremely new to this forum ,but i need alot of help starting the MM. While try to run the software i rann across this error :
      PM2] Init System found: systemd
      Platform systemd
      Template
      [Unit]
      Description=PM2 process manager
      Documentation=https://pm2.keymetrics.io/
      After=network.target
      [Service]
      Type=forking
      User=pi
      LimitNOFILE=infinity
      LimitNPROC=infinity
      LimitCORE=infinity
      Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
      Environment=PM2_HOME=/home/pi/.pm2
      PIDFile=/home/pi/.pm2/pm2.pid
      Restart=on-failure
      ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
      ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
      ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
      [Install]
      WantedBy=multi-user.target
        sdetweil @Techgator2
        @Techgator2 I don’t see an error there… I see the PM2 config for some task
        • T Offline
          Techgator2 @sdetweil
          @sdetweil Honestly I think uninstall Mm and starting over is my best option. Please advise how to delete the current software off a Raspberry pi 3 b .
            @Techgator2 from your home folder do
            rm -rf MagicMirror
            but you shouldn’t need to…
            after the git clone, you did npm install from the MagicMirror folder and then npm start to start it.
            right?
            • T Offline
              Techgator2
              I’m unsure .
              1 Reply Last reply Reply Quote -1
              • T Offline
                Techgator2
                After inputting the command ls . It listed the insall app as Magim2 . Not sure why but i believe that’s the magic mirror file but somenow its been rename . how do I delete and start fresh ?
                please explain in K.I.S.S format.
                  @Techgator2
                  # go to home folder
                  cd ~
                  # erase old installation of MagicMirror
                  rm -rf MagicMirror
                  # get the current MagicMirror repo here
                  git clone https://github.com/MichMich/MagicMirror.git
                  # change into its directory
                  cd MagicMirror
                  # install all the dependencies
                  npm install
                  # start mirror with default config
                  npm start
