    Problems with Config.js on Pi4 BlackScreen
    24 Posts 2 Posters 9.7k Views 2 Watching
      sdetweil @dazza120
      @dazza120 sorry, what is “it’s”?
      D 1 Reply Last reply
        dazza120 @sdetweil
        @sdetweil /home/pi/MagicMirror The mm.sh should it contain text?
          sdetweil @dazza120
          @dazza120 sorry… what is completely empty? mm.sh is in installers folder
            dazza120 @sdetweil
            @sdetweil i unhide my files and one is in the location i said with no text and the other is in installer as you said with text
              sdetweil @dazza120
              @dazza120 remove the one in MagicMirror… useless
              Fix the one in installers
                dazza120 @sdetweil
                @sdetweil ok done, what to do now. ive just copied the installer one and overwrite the magic mirror path one
                  sdetweil @dazza120
                  @dazza120 which one does pm2 want to use? I am not near my computer so can’t get the list of pm2 commands.
                  pm2 – help
                  Did u edit the path in mm.sh?
                    dazza120 @sdetweil
                    @sdetweil no i mearly placed it in the magicmirror folder path. its set to Cd /MagicMirror folder already and pm2 -help isnt displaying a list of pm2 commands
                      sdetweil @dazza120
                      @dazza120 inside needs to be
                      cd /home/pi/MagicMirror
                      DISPLAY=:0 npm start
                        dazza120 @sdetweil
                        @sdetweil changed it what now mate
                          sdetweil @dazza120
                          @dazza120 did u try pm2 now?
                            dazza120 @sdetweil
                            @sdetweil pm2 start or the dev thing?
                              sdetweil @dazza120
                              @dazza120
                              Let’s get npm start dev working
                                dazza120 @sdetweil
                                @sdetweil still nothing in the dev console mate, i can start the whole build over again but everytime i go to change the config it doesnt work
                                  sdetweil @dazza120
                                  @dazza120 ok, start again… change the config?
                                  So, you install a module. If it has package.json file you run npm install in the module folder
                                  Then edit config.js and add
                                  Module structure.
                                    module:'somename',
                                  To the modules array.
                                  If think syntax error, from the MagicMirror folder do,
                                  npm  run config:check
                                  D 2 Replies Last reply
                                    dazza120 @sdetweil
                                    @sdetweil yep im cd-ing into the module folder and then running npm install, ill start over again and go through it slowly but ive probably built the mirror 20 from scratch no issues before with config but ive altered it too much now thinking that was it so its from scratch now but copying back the old config should have sorted any of those issues, does your installer work?
                                      dazza120 @sdetweil
                                      @sdetweil I think i found the problem mmm-nest-status install messes up the MM install, i think other are having simular things with other modules. i installed MMM-SystemStats changed the config file tested it and it was working find, i installed mmm-nest-status and didn’t alter the config for that so that should have just ment it wouldn’t run that module. i have attached the code below does this shead any light?
                                      pi@raspberrypi:~ $ cd MagicMirror/modules
                                      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/BenRoe/MMM-SystemStats
                                      Cloning into 'MMM-SystemStats'...
                                      remote: Enumerating objects: 22, done.
                                      remote: Counting objects: 100% (22/22), done.
                                      remote: Compressing objects: 100% (14/14), done.
                                      remote: Total 231 (delta 10), reused 16 (delta 8), pack-reused 209
                                      Receiving objects: 100% (231/231), 88.08 KiB | 578.00 KiB/s, done.
                                      Resolving deltas: 100% (122/122), done.
                                      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SystemStats
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ npm install
                                      npm notice created a lockfile as package-lock.json. You should commit this file.
                                      added 1 package from 1 contributor and audited 1 package in 1.265s
                                      found 0 vulnerabilities
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ cd
                                      pi@raspberrypi:~/MagicMirror $ npm  run config:check
                                      > magicmirror@2.8.0 config:check /home/pi/MagicMirror
                                      > node tests/configs/check_config.js
                                      Checking file...  /home/pi/MagicMirror/config/config.js
                                      Your configuration file doesn't contain syntax errors :)
                                      pi@raspberrypi:~/MagicMirror $ cd modules
                                      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git
                                      Cloning into 'mmm-nest-status'...
                                      remote: Enumerating objects: 135, done.
                                      remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135
                                      Receiving objects: 100% (135/135), 65.27 KiB | 718.00 KiB/s, done.
                                      Resolving deltas: 100% (77/77), done.
                                      pi@raspberrypi:~/MagicMirror/modules $ cd mmm-nest-status
                                      pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ npm install
                                      npm WARN deprecated undefined@0.1.0: this package has been deprecated
                                      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                                      npm WARN modules No description
                                      npm WARN modules No repository field.
                                      npm WARN modules No README data
                                      npm WARN modules No license field.
                                      removed 1 package in 1.141s
                                      pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ cd
                                      pi@raspberrypi:~ $ pm2 restart MagicMirror
                                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                                      [PM2] [MagicMirror](0) ✓
                                      │ Name        │ id │ mode │ status │ ↺ │ cpu │ memory   │
                                      │ MagicMirror │ 0  │ fork │ online │ 2 │ 0%  │ 2.5 MB   │
                                       Use `pm2 show <id|name>` to get more details about an app
                                      pi@raspberrypi:~ $ npm  run config:check
                                      npm ERR! code ENOENT
                                      npm ERR! errno -2
                                      npm ERR! syscall open
                                      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                      npm ERR! enoent This is related to npm not being able to find a file.
                                      npm ERR! enoent
                                      npm ERR!     /home/pi/.npm/_logs/2019-07-13T20_08_21_703Z-debug.log
                                      pi@raspberrypi:~ $
                                      Complete log from .npm folder
                                      1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'run', 'config:check' ]
                                      2 info using npm@6.10.1
                                      3 info using node@v10.15.2
                                      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                                      5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
                                      6 verbose cwd /home/pi
                                      7 verbose Linux 4.19.57-v7l+
                                      8 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "run" "config:check"
                                      9 verbose node v10.15.2
                                      10 verbose npm  v6.10.1
                                      11 error path /home/pi/package.json
                                      12 error code ENOENT
                                      13 error errno -2
                                      14 error syscall open
                                      15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                      16 error enoent This is related to npm not being able to find a file.
                                      17 verbose exit [ -2, true ]
