    MMM-Clap
    25 Posts 4 Posters 9.5k Views 2 Watching
    • Cr4z33C
      Cr4z33 @Guest
      @Sean I’ve got one USB mic.
      Sorry I am not sure you gave me the solution. :smiling_face_with_open_mouth_cold_sweat:
      Say again?
      ? 1 Reply Last reply
        A Former User @Cr4z33
        @Cr4z33
        MMM-Clap and MMM-Hotword will compete each other to take one mic. I think you’d better to use just one module. At least one module at a time. You can make juggling with CLAP_RESUME, CLAP_PAUSE, HOTWORD_RESUME, HOTWORD_PAUSE to confirm only one module uses a mic at a time. But too complex. not recommended.
        Cr4z33C 1 Reply Last reply
          smarthome @Guest
          @Sean
          The scenario is:
          Step 1: Clap action
          Step 2: Clap sound detected, MMM Clap send output notification to MMM Page Selector while Mic still not released yet
          Step 3: MMM Page Selector receive input notification then change page
          Step 4: MMM Page Selector sends output notification CLAP_PAUSE to MMM Page Selector to release the MIC and waitting for next clap sound
            A Former User @smarthome
            @smarthome said in MMM-Clap:
            Step 1: Clap action
            In this real usage, You don’t need to release mic at all. MMM-Page-Selector doesn’t use any mic. So why do you need to release mic for changing pages? Mic Releasing is needed only when your other module wants to use the same Mic (like MMM-AssistantMk2). Unless you set restart:false, MMM-Clap will be restarted automatically after detection regardless other module’s job.
            And If you REALLY want to have a feature - sending some specific notification from specific module -, request module creator to do so. But with this case, I don’t think it needs.
              A Former User @Guest
              @smarthome
              @Sean said in MMM-Clap:
              Fortunately(???) There is already a solution about this;
              As far as I know MMM-Page-Selector could emit PAGE_CHANGED notification.
              All you need is to translate that notification to what you need. And MMM-NotificationTrigger module could do that job.
              • Cr4z33C
                Cr4z33 @Guest
                @Cr4z33
                Oh now I got it.
                Thanks however I will then keep using MMM-Hotwords.
                Too precious for my voice command needs hehe. 😁
                  smarthome @Guest
                  @Sean
                  I’d already, but didn’t work
                  		  module: "MMM-NotificationTrigger",
                  		  //This module works in Background, so you don't need to describe `position`.
                  			useWebhook: false, // If you want to activate webhook as Notification emitter, set true. (eg. IFTTT)
                  			triggers:[ // Array of triggers.
                  				trigger: "PAGE_CHANGED", //REQUIRED
                  				triggerSenderFilter: (sender) => { //OPTIONAL should return true or false
                  				  if (sender == "MMM-Page-Selector") {
                  					return true
                  				  return false
                  				triggerPayloadFilter: (payload) => { //OPTIONAL should return true or false
                  				  if (typeof payload.value !== 'undefined' && payload.value > 0) {
                  					return true
                  				  return false
                  				fires: [ // Array of fires. You can enable multi-firing with one trigger.
                  					fire:"CLAP_RESUME", //REQUIRED
                  					payload: (payload) => { //OPTIONAL. transform received payload to what your target module wants.
                  					  return payload
                  		 //           delay: 1000, //OPTIONAL, if this is set, your outgoing notification will be fired after delay.
                  		 //           exec: "ls -l" //OPTIONAL, if exists, this script will be executed, and the result will be returned with "OUTGOING_NOTIFICATION_RESULT" and payload.  Can also be specified as a function which accepts the payload as an argument and returns the command to execute.
                    @smarthome
                    Repeating again; Why do you need CLAP_RESUME/CLAP_PAUSE on page changing? Without them the module will work. I’m a little embarrassed to understand why you need it.
                      smarthome
                      @Sean
                      With MMM Page selector, If I not turn page, i must wait for changing by itself
                      That’s why I use CLAP to turn page quickly
                      With MMM Asisstant MK2, I need use MMM Hotword to see my request, if I use another module to trigger, I can’t see it
                      finally, CLAP and Hotword use at the same time…
                        @smarthome
                        I doubted you might want to use Clap and Hotword together… Maybe possible, but don’t recommend personally.
                        The easiest solution might be using 2 mics. :D
                        Anyway, I’ll look inside how to use both module together, (Even I haven’t tried) but it needs some time. sorry.
                          smarthome @Guest
                          @Sean
                          OK. Tks for your help & advise. Waitting
                            smarthome
                            Dear @Sean
                            Clap one, it detects 1 but the icon disappears after that
                            Wait some seconds, clap again and it show the error in log
                            Can you help me to fix that
                            Tks!
                              @smarthome
                              Can you share your config about MMM-Clap? eouia0819@gmail.com
