    Basic Calendar log errors
    9 Posts 2 Posters 2.1k Views 2 Watching
      sdetweil @johntech
      @johntech yes, looks like the calendar data has an empty repeating rule and the library code we use
      can’t handle that
      edit (nano) the MagicMirror/node_modules/rrule/dist/es5/rrule.js
      find (ctrl w)
      options.byeaster = Number(value);
      and add these two lines
           case '':
              break;
      so it looks like this
                  case 'BYEASTER':
                      break;
                 case '':
      		break;
        johntech @sdetweil
        @sdetweil said in Basic Calendar log errors:
        >  case '':
        > 		break;
        Good!! That fixed the issue of the calendar not displaying , but now it is showing double entries in the list. 2 - Easters, Mother’s Day, President’s day etc.
          sdetweil @johntech
          @johntech said in Basic Calendar log errors:
          cause there are two entries in the file
          looks like calendarlabs.com is having trouble
            johntech @sdetweil
            Ok. Is it possible to download the file, edit it and use is locally?
            Thank you for the help!!
            John
              sdetweil @johntech
              @johntech sure… use the url (change webcal to https)
              edit the downloaded file (there are multiples of all the entries)
              copy the file to the MagixMirror/modules folder (thats where the MM web server is pointing)
              then edit the url in the config entry to
              “modules/???” // ics filename
                johntech @sdetweil
                Sorry for the misunderstanding but is this what you meant?
                url: “https://modules/US_Holidays.ics”
                  sdetweil @johntech
                  @johntech http://localhost:8080/…
                    johntech @sdetweil
                    Thank you !!! I wasn’t thinking localhost. Still learning!!
