MM not filling screen
screen
12 Posts 2 Posters 2.5k Views 2 Watching
    reallykeene
    https://www.reddit.com/r/MagicMirrors/comments/fqc4tn/help_my_mirror_wont_fill_the_screen/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
    My magic mirror will not fill the entire TV monitor screen. Can anyone help solve this issue?
    I have adjusted the over scan as well as the mirrors css file.
    S 1 Reply Last reply Mar 28, 2020, 11:44 AM Reply Quote 0
      sdetweil @reallykeene
      @reallykeene so, lets back up one step, and try the original main.css
      do
      cd ~/MagicMirror/css
      mv main.css save-main.css
      cd ..
      git checkout css/main.css
      then restart MM
      and show us the display output…
      R 1 Reply Last reply Mar 28, 2020, 3:18 PM Reply Quote 0
        reallykeene @sdetweil
        @sdetweil I got a fatal: not a git repository. It then only shows my traffic module with the screen black. I still have the bar of the desktop to the right.
        S 1 Reply Last reply Mar 28, 2020, 3:22 PM Reply Quote 0
          @reallykeene how did you install MM? git clone? or zip file?
          R 1 Reply Last reply Mar 28, 2020, 3:30 PM Reply Quote 0
            @sdetweil git clone
            It was on another monitor. I’ve just changed to a TV for the display.
            Should I reboot the operating system for the pie on the new screen?
            S 1 Reply Last reply Mar 28, 2020, 3:31 PM Reply Quote 0
              @reallykeene yes, when u change screens by moving cable, after boot the hardware doesn’t always get it right
              (my pi 4 cannot see the second display if not present at power on)
              I had a typo in my commands above (lowercase m in MagicMirror)
              R 1 Reply Last reply Mar 28, 2020, 3:33 PM Reply Quote 0
                @sdetweil Is there an easy way to do that?
                The only way I know would be to save all my work onto a hard drive and then resetting the pie from scratch. I’m pretty new to this.
                S 1 Reply Last reply Mar 28, 2020, 3:35 PM Reply Quote 0
                  @reallykeene won’t lose anything on pi, with sd card…
                  sudo shutdown reboot
                  for restart, if it works, good…
                  if need power off
                  sudo shutdown now -h
                  wait til light goes off
                  power back on (however u do that… pull/re-insert power cord, use switch)
                  R 1 Reply Last reply Mar 28, 2020, 3:45 PM Reply Quote 0
                    @sdetweil The desktop rebooted to the full size of the screen correctly. But the magic mirror still looks like the original picture and it’s not stretching to the full size of the screen in width.
                    S 1 Reply Last reply Mar 28, 2020, 3:53 PM Reply Quote 0
                      @reallykeene try the updated commands above
                      R 1 Reply Last reply Mar 28, 2020, 4:17 PM Reply Quote 0
