    Where is the run-start.sh located?
    10 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @Teun
      @Teun they removed it in 2.11
      Get it from here
      https://github.com/sdetweil/MagicMirror_scripts?files=1
      • T Offline
        Teun
        Thanks for the reply. So if I understand correctly, I should add this file in the MagicMirror folder and then I can proceed the steps mentioned in the other topic? Is that correct?
        Only thing I should keep in mind is not to use the “npm run start” command any more, but copy paste the link to start the application?
        Sorry for the questions, but I’m a little uncertain how to fix the dual monitor problem.
          sdetweil @Teun
          @Teun siorry, I dont know what the problem is…
          if you used my install script all was handled for you…
          run -start is no longer used except for armv6l devices (pi0 and pi2) where electron is no longer available.
          what do you wan to do with dual display?
          I run it all the time and have MM open on the second display
          • T Offline
            Teun
            I want to have the MM on 2 screens. I want to have both screens alligned above each other so I can have a big surface to present the MM app on the left side of the mirror. But then the MM app should be shown on both screens, so it would look like these 2 screens are 1 big screen.
              sdetweil @Teun
              @Teun so far I have not found a way to make dual screen into one screen at startup.
              when u maximize it goes full on the current screen.
              I don’t know if u take maximize off and set the actual full dimensions if it will fill both screens
              you should be able to do the parameters with the electron Options in config.js
              • T Offline
                Teun @sdetweil
                @sdetweil , thanks for the reply. I did some adaptations in the electron.js file, as I couldn’t find any specific settings in the config.js file. That’s why I thought maybe the electron.js file was the correct file to change? By changing the electron.js file, I already could change the full screen setting. So now I can have a smaller screen when I do the MagicMirror start (npm run start). Then I can manually adapt the length of the screen/frame so it is spreaded over the 2 monitors. Only remaining problem is when I close the MM app and I start again (by using npm run start), I still have the smaller screen and I again need to manually change the dimensions so the screen would fill the 2 monitors. Do you have any idea how that can be fixed? Thanks!
                  sdetweil @Teun
                  @Teun well, I would try using the electronOptions field in config.js
                  var config = {
                  	electronOptions:{x:0, backgroundColor:'#00000001',  width:800, height:1024, fullscreen:false, kiosk:false },
                  	address: "0.0.0.0", // Address to listen on, can be:
                  and change the width/height
                  may have to comment this out in electron.js
                  		mainWindow.on("leave-full-screen", function() {
                  			mainWindow.setFullScreen(true);
                    @Teun
                    you might also be able to use these
                    minWidth Integer (optional) - Window's minimum width. Default is 0.
                    minHeight Integer (optional) - Window's minimum height. Default is 0.
                    see all the settings
                    https://www.electronjs.org/docs/api/browser-window
                    • T Offline
                      Teun @sdetweil
                      @sdetweil This was what I needed! Many thanks for helping me with this problem! Issue solved!
