    Return to first page after a delimited time
    4 Posts 2 Posters 693 Views 2 Watching
      Burnallover
      Hi everybody,
      First of all thank you for this software and all contributor, i’m french so sorry in advance for my bad english.
      i have MagicMirror with some pages, and i search a tip to automatically return to the first page after a delimited time.
      Is it a simple module or a tip on the module MMM-pages to do it automatically?
      Thanks in advance :)
        chassain 0
        salut.
        You can use mmm pages and define display time for all pages. there is an automaticallly loop
          Burnallover
          Thanks for your reply,
          The problem is i have some confidential information on other page and i don’t want each page to loop.
          I just want that when i manually go on the third page, after 30 sec MagicMirror automatically return on the first one.
            Burnallover
            i solved my case.
            probably not the better way but here is the js modified :
            Module.register('MMM-pages', {
              // We require the older style of function declaration for compatibility
              // reasons.
               * By default, we have don't pseudo-paginate any modules. We also exclude
               * the page indicator by default, in case people actually want to use the
               * sister module. We also don't rotate out modules by default.
              defaults: {
                modules: [],
                excludes: [], // Keep for compatibility
                fixed: ['MMM-page-indicator'],
                animationTime: 1000,
                rotationTime: 0,
                rotationFirstpage:0,
                rotationDelay: 10000
               * Apply any styles, if we have any.
              getStyles: function () {
                return ['pages.css'];
               * Modulo that also works with negative numbers.
               * @param {number} x The dividend
               * @param {number} n The divisor
              mod: function (x, n) {
                return ((x % n) + n) % n;
               * Pseudo-constructor for our module. Makes sure that values aren't negative,
               * and sets the default current page to 0.
              start: function () {
                this.curPage = 0;
                this.rotationPaused = false;
                // Compatibility
                if (this.config.excludes.length) {
                  Log.warn('[Pages]: The config option "excludes" is deprecated. Please use "fixed" instead.');
                  this.config.fixed = this.config.excludes;
                // Disable rotation if an invalid input is given
                this.config.rotationTime = Math.max(this.config.rotationTime, 0);
                this.config.rotationDelay = Math.max(this.config.rotationDelay, 0);
                this.config.rotationFirstpage = Math.max(this.config.rotationFirstpage, 0);
               * Handles incoming notifications. Responds to the following:
               *   'PAGE_CHANGED' - Set the page to the specified payload page.
               *   'PAGE_INCREMENT' - Move to the next page.
               *   'PAGE_DECREMENT' - Move to the previous page.
               *   'DOM_OBJECTS_CREATED' - Starts the module.
               *   'QUERY_PAGE_NUMBER' - Requests the current page number
               * @param {string} notification the notification ID
               * @param {number} payload the page to change to/by
              notificationReceived: function (notification, payload) {
                switch (notification) {
                  case 'PAGE_CHANGED':
                    Log.log('[Pages]: received a notification '
                      + `to change to page ${payload} of type ${typeof payload}`);
                    this.curPage = payload;
                    this.updatePages();
                    break;
                  case 'PAGE_INCREMENT':
                    Log.log('[Pages]: received a notification to increment pages!');
                    this.changePageBy(payload, 1);
                    this.updatePages();
                    break;
                  case 'PAGE_DECREMENT':
                    Log.log('[Pages]: received a notification to decrement pages!');
                    // We can't just pass in -payload for situations where payload is null
                    // JS will coerce -payload to -0.
                    this.changePageBy(payload ? -payload : payload, -1);
                    this.updatePages();
                    break;
                  case 'DOM_OBJECTS_CREATED':
                    Log.log('[Pages]: received that all objects are created;'
                      + 'will now hide things!');
                    this.sendNotification('MAX_PAGES_CHANGED', this.config.modules.length);
                    this.animatePageChange();
                    this.resetTimerWithDelay(0);
                    break;
                  case 'QUERY_PAGE_NUMBER':
                    this.sendNotification('PAGE_NUMBER_IS', this.curPage);
                    break;
                  case 'PAUSE_ROTATION':
                    if (!this.rotationPaused) {
                      Log.log('[Pages]: pausing rotation due to notification');
                      clearInterval(this.timer);
                      clearInterval(this.delayTimer);
                      this.rotationPaused = true;
                    } else {
                      Log.warn('[Pages]: Was asked to paused but rotation was already paused!');
                    break;
                  case 'RESUME_ROTATION':
                    if (this.rotationPaused) {
                      Log.log('[Pages]: resuming rotation due to notification');
                      this.resetTimerWithDelay(this.rotationDelay);
                    } else {
                      Log.warn('[Pages]: Was asked to resume but rotation was not paused!');
                    break;
                  default: // Do nothing
               * Changes the internal page number by the specified amount. If the provided
               * amount is invalid, use the fallback amount. If the fallback amount is
               * missing or invalid, do nothing.
               * @param {number} amt the amount of pages to move forward by. Accepts
               * negative numbers.
               * @param {number} fallback the fallback value to use. Accepts negative
               * numbers.
              changePageBy: function (amt, fallback) {
                if (typeof amt !== 'number') {
                  Log.warn(`[Pages]: ${amt} is not a number!`);
                if (typeof amt === 'number' && !Number.isNaN(amt)) {
                  this.curPage = this.mod(
                    this.curPage + amt,
                } else if (typeof fallback === 'number') {
                    this.curPage + fallback,
               * Handles hiding the current page's elements and showing the next page's
               * elements.
              updatePages: function () {
                // Update iff there's at least one page.
                if (this.config.modules.length !== 0) {
                    this.resetTimerWithDelay(this.config.rotationDelay);
                  this.sendNotification('NEW_PAGE', this.curPage);
                } else { Log.error("[Pages]: Pages aren't properly defined!"); }
               * Animates the page change from the previous page to the current one. This
               * assumes that there is a discrepancy between the page currently being shown
               * and the page that is meant to be shown.
              animatePageChange: function () {
                const self = this;
                // Hides all modules not on the current page. This hides any module not
                // meant to be shown.
                MM.getModules()
                  .exceptWithClass(this.config.fixed)
                  .exceptWithClass(this.config.modules[this.curPage])
                  .enumerate(module => module.hide(
                    self.config.animationTime / 2,
                    { lockString: self.identifier }
                // Shows all modules meant to be on the current page, after a small delay.
                setTimeout(() => {
                  MM.getModules()
                    .withClass(self.config.modules[self.curPage])
                    .enumerate((module) => {
                      module.show(
                }, this.config.animationTime / 2);
               * Resets the page changing timer with a delay.
               * @param {number} delay the delay, in milliseconds.
              resetTimerWithDelay: function (delay) {
                if (this.config.rotationTime > 0) {
                  // This timer is the auto rotate function.
                  // This is delay timer after manually updating.
                  const self = this;
                  this.delayTimer = setTimeout(() => {
                    self.timer = setInterval(() => {
                      self.sendNotification('PAGE_INCREMENT');
                      self.changePageBy(1);
                      self.updatePages();
                    }, self.config.rotationTime);
                  }, delay);
                }if (this.config.rotationFirstpage > 0) {
                  const self = this;
                      self.sendNotification('PAGE_CHANGED', 0);
                      self.changePageBy(-this.curPage);
                      self.updatePages();
                    }, self.config.rotationFirstpage);
                  }, delay);
