Config problems
8 Posts 2 Posters 604 Views 2 Watching
    dawookie1979
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config = {
    	port: 8080,
    	language: "en",
    	timeFormat: 24,
    	units: "metric",
    			module: "alert",
    			module: "clock",
    			position: "top_left"
    			header: "xxxxx Family Calendar",
    			position: "bottom_left",
    						symbol: "xxxxx Family",
    						url: "https://calendar.google.com/calendar/ical/xxxxx.com/public/basic.ics"
    		{				symbol: "uk holiday",
    				url: "https://calendar.google.com/calendar/ical/en-gb.uk%23holiday%40group.v.calendar.google.com/public/basic.ics"
    			module: "currentweather",
    				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
    				appid: "xxxxx"
    			module: "weatherforecast",
    			header: "Weather Forecast",
    				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
    				appid: "xxxxx"
    	module: 'MMM-SoccerLiveScore',
    	position: 'left',
    	header: 'Live Football Scores',
    		leagues: [17],
            showNames: true,
            showLogos: true,
            displayTime: 60 * 1000,
            showTables: false
      module: "MMM-CountEvents",
      position: "left",
        groupOrder: [], // When it set, the group of event which has same group name will be displayed and be rotated to others by groupInterval
        groupInterval: 1000*5,
        refreshInterval:1000*1,
        locale: null, //related with `humanize` (if omitted or null, MM default locale will be used.)
        template: "<p class=\"title\">%TITLE%</p><p class=\"output\">%OUTPUT%</p>",
        //You can modify HTML rendering.
        //%TITLE% : will be replaced by event.title
        //%OUTPUT% : will be replaced by event.output
        events: [
            group: "default",
            title: "Daniel's Alcohol Free",
            targetTime: "2019-09-24", // See the time format section.
          	yearlyRepeat: false, // if this event should be refreshed yearly, set this to `true`. targetTime will be replaced the closest next date of this year or the next year.
          	unit: "days", // "years", "months", "weeks", "days", "hours", "minutes", "seconds"...
            //but if you set `humanize` to true, `unit` will be ignored.
          	humanize:false, //If set as `true`, %RESULT% will be humanized. (e.g "a year ago")
            absolute:true, //If set as `false`, remain duration will be `plus number`, past duration will be `minus number`. If set as `true`, all duration will be `plus number`
            ignore:null, //Available [null, "before", "after"]. This event will not be displayed `before|after` targetTime
            className: "", //You can assign class name to this event for beautifying with CSS.
          	output: "%RESULT% days passed", //You can modify output text. %RESULT% will be result of countdown/up calculation with above options.
            group: "default",
            title: "Emma's Alcohol Free",
            targetTime: "2019-09-26", // See the time format section.
    		module: 		'MMM-UKNationalRail',
    		position: 		'bottom_left',
    		header:			'Whittlesford Parkway',		//Optional - delete this line to turn OFF the header completely
    			stationCode: 		'WLF', 		// CRS code for station
    			app_id: 			'xxxxx', 		// TransportAPI App ID
    			app_key: 			'xxxxx', 		// TransportAPI App Key
    			maxResults: 		5,  		//Optional - Maximum results to display.
    			showOrigin: 		false   	//Optional - Show the origin of the train in the table
    			module: "newsfeed",
    			position: "bottom_bar",
    				feeds: [
    						title: "BBC News",
    						url: "http://feeds.bbci.co.uk/news/rss.xml?edition=uk"
    				showSourceTitle: true,
    				showPublishDate: true
    S 1 Reply Last reply Jul 14, 2020, 9:12 PM Reply Quote 0
      dawookie1979
      can anyone see problems?
        sdetweil @dawookie1979
        @dawookie1979
        u have this in the middle of the modules list
          dawookie1979
          yes i have removed that, but still no joy
          S 1 Reply Last reply Jul 14, 2020, 9:30 PM Reply Quote 0
            @dawookie1979 my post did not show All that was trouble
              dawookie1979
              lol, ok. i have added/taken away {}. it now seems to work :0 . Thank you for your help
                dawookie1979
                how do i mark this as solved :)
                S 1 Reply Last reply Jul 14, 2020, 9:54 PM Reply Quote 0
                  @dawookie1979 u didn’t open it as an issue that is closable, so only can edit the title to add solved
