    Calendar not displaying what I want
    4 Posts 2 Posters 1.4k Views 2 Watching
    • I
      icmike52
      I have been searching and I’m getting more confused.
      My Google calendar (My Calendar) contains a few calendars. Holidays in United States show up under Other calendars. I mistakenly assumed by using the Secret address for MyName Calendar settings in iCal format would show me everything. It does not. MM only shows birthdays. Nothing else. I’ve tried several different ways but no matter what I change, only birthdays show. My config.js runs, just doesn’t show both.
      	header: "My Calendar",
      	symbol: "birthday-cake",
      	url: "https://calendar.google.com/calendar/ical/xxxxx%40gmail.com/private-xxxxx/basic.ics",
      	user: 'xxxxx@gmail.com',
      	password: 'xxxxx',
      	method: 'basic'
      	symbol: "calendar-check-o ",
      	url: "https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FNew_York"
      Raspberry Pi 3
      MagicMirror 2.12.0
      Always learning
        sdetweil @icmike52
        @icmike52 the url for a calendar must download an ics file. I suspect the second does not. put the url in a browser on the pi. it is not logged in as you.
        • I
          icmike52
          For anyone having trouble with MM calendar not displaying their Google calendar correctly, please read on…
          The default calendar module in MM works very well. The developers deserve a lot of credit.
          You first have to understand how Google calendar works.
          1. My Google Calendar: I assumed that if it was in My main Google Calendar, it would show in my MM calendar.
            This is not true. Google just conveniently merges all of your calendars into one.
            For instance, In my Google Calendar settings, I added a “Holidays in the United States” additional calendar.
            In settings, it has public url but no iCal format so it will never show in MM.
            To get Holidays in the U.S. to display, I had to go outside Google calendar. See below in my config.
            If you’ve subscribed to an addional calendar, like a sport team calendar from Stanza, in Settings look for
            its Secret address in iCal format. If your calendar does not show this option, (only has a url) it won’t show
            in MM. It must start with an http and end with .ics.
          2. Birthdays: In your Google calendar, there is a checkbox to display birthdays.
            This works great as long as the person is in your Google contacts and you have set their
            birthdate INSIDE the contact details. If you just added a persons birthday to your
            calendar as a recurring event like I did, the checkbox to display Birthdays is meaningless.
          Also in case you did not know, there are tons of calendar symbols at https://fontawesome.com/icons?from=io
          that work natively in the calendar module.
          Here is my config that works. (But hiding my credentials, of course)
                  maximumNumberOfDays: 60,
          	url: "https://calendar.google.com/calendar/ical/xxxxxx%40gmail.com/private-xxxxxxxx/basic.ics",
          	user: 'xxxxxxxx@gmail.com',
          	password: 'xxxxxxxxxxx',
          	method: 'basic'
                  symbol: "hockey-puck",
                  url: "https://calendar.google.com/calendar/ical/xxxxxxxstanza calendar/private-xxxxxxxxxxxxxxx/basic.ics",
                  symbol: "football-ball",
                  url: "https://calendar.google.com/calendar/ical/xxxxxxstanza calendar/private-xxxxxxxx/basic.ics",
          	symbol: "glass-cheers",
                  url: "https://www.officeholidays.com/ics-fed/usa"
          Please feel free to add anything about Google calendar integration that I missed.
          Raspberry Pi 3
          MagicMirror 2.12.0
          Always learning
            sdetweil @icmike52
            @icmike52 the calendar module processes ics files. nothing else.
            as you’ve noted, what shows on your Google calendar display may have nothing to do with what data u can get from your combined ‘calendar’ sources.
            the other note is that your browser on your PC gets your user credentials, and logs on as you. the pi does not, so each data source has to be public or specially private for the mm code to access it, or u have to provide credentials for many sources.
