    MMM-RouteInfo
    8 Posts 4 Posters 3.0k Views 4 Watching
    • Q Offline
      QNimbus
      Also, just to clarify - I’ve made an attempt to create a TypeScript definitions file for MagicMirror. It’s by no means complete, but I would really appreciate it if anyone would like to help/collaborate on this specific topic.
      The definition files are in my GitHub repo in the ‘src’ folder.
      Being able to use TypeScript to develop for MagicMirror would be a great improvement if you ask me ;-)
      • H Offline
        henrikra
        Just wanted to let you know that I made initial TS pr for MagicMirror to add simple types. They aren’t complete but you gotta start somewhere :) https://github.com/MichMich/MagicMirror/pull/1121
        • W Offline
          winstonma
          @henrikra I am not sure if it is appropriate but I would like to use Nullish coalescing operator.
          Is it supported in native MagicMirror? Thanks
            sdetweil @winstonma
            @winstonma as I replied in your other topic it needs node version 14 or higher and maybe a browser mod
            u can you chromium over the mm server to test, if u have node 14
            note it also depends where the operator is used
            if in node_helper, then u need node 14 on the server. if I the modulename.js then wherever the browser runs
            • W Offline
              winstonma
              Thanks @sdetweil
              As there are some TS support added 2 years ago (and I am not sure how much TS support is added), therefore I have this question.
              Yes the browser support on Nullish coalescing operator started half year back but I need the operator on the backend code (which is the node part). I wonder if I could add some npm modules to make it happen.
                sdetweil @winstonma
                @winstonma no idea. looks like a language thing
                • W Offline
                  winstonma
                  @sdetweil I read this article it gives me some hope that I could add some TS support in the existing module.
