    Unable to start magic mirror via flask-ask intent
    3 Posts 2 Posters 422 Views 2 Watching
      ashokkn
      My alexa skill intent function just executes below command to run a .sh file which contains just two lines but magic mirror wont run. But if execute the same .sh file from cmd line, mm works perfectly. Please assist …!!
      cd ./MagicMirror
      npm run start
      [22682:1206/182424.385159:FATAL:atom_main_delegate.cc(210)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
        sdetweil @ashokkn
        @ashokkn u are running as root. That is a bad thing
          ashokkn
          not running as root -
          [2020-12-07 11:53:51.413] [ERROR] Whoops! There was an uncaught exception…
          [2020-12-07 11:53:51.414] [ERROR] Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          at doWrite (_stream_writable.js:413:19)
          at writeOrBuffer (_stream_writable.js:401:5)
          at Socket.Writable.write (_stream_writable.js:301:11)
          at Object.con. [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
          at App. (/home/pi/MagicMirror/js/electron.js:93:6)
          at App.emit (events.js:205:15)
          [2020-12-07 11:53:51.415] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-12-07 11:53:51.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
