    Update got me cannot lock ref
    7 Posts 2 Posters 3.3k Views 2 Watching
    • sweupS Offline
      sweup
      Got this error message when trying to update, I tried some Google suggestions but none worked. Any suggestions?
      pi@raspberrypi:~/MagicMirror $ git pull && npm install
      error: cannot lock ref 'refs/tags/v2.13.0': unable to resolve reference 'refs/tags/v2.13.0': reference broken
      From https://github.com/MichMich/MagicMirror
       ! [new tag]           v2.13.0    -> v2.13.0  (unable to update local ref)
      error: cannot lock ref 'refs/tags/v2.14.0': unable to resolve reference 'refs/tags/v2.14.0': reference broken
       ! [new tag]           v2.14.0    -> v2.14.0  (unable to update local ref)
        sdetweil @sweup
        @sweup try this
        git remote prune origin
        sweupS 1 Reply Last reply Reply Quote 0
        • sweupS Offline
          sweup @sdetweil
          @sdetweil said in Update got me cannot lock ref:
          thx, I tried this
          pi@raspberrypi:~/MagicMirror $ git remote prune origin
            sdetweil @sweup
            @sweup ok
            rm .git/refs/tags/v2.13.0
            rm .git/refs/tags/v2.14.0
            then the purge refs command again
            • sweupS Offline
              sweup @sdetweil
              Thanks! I had to make a git stash but then it worked out.
              Unrelated - is it “safe” to update Node.js and do a sudo apt update and sudo apt upgrade of the Rpi, or could I expect issues? Sorry for noob Qs
              npm WARN npm npm does not support Node.js v10.23.1
              npm WARN npm You should probably upgrade to a newer version of node as we
              npm WARN npm can't make any promises that npm will work with this version.
              npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
              npm WARN npm You can find the latest version at https://nodejs.org/
                sdetweil @sweup
                @sweup ignore the warning, use as is
                • sweupS Offline
                  sweup @sdetweil
                  @sdetweil ok, thanks for your help!
