    PIR Sensor won't wake up
    22 Posts 7 Posters 10.4k Views 7 Watching
      Sceetch @dbg
      @dbg i’m using Raspberry Pi 3 Modell B Plus (B +)
      I have no idea whats wrong.
      I can change the delay time value randomly. There is no effect. After exact 2 minutes the screen turn off.
      Could it be, there is something activated in the tvservice?
      S D 3 Replies Last reply Reply Quote 0
        sdetweil @Sceetch
        @sceetch off is because the module does this no motion was detected
          dbg @Sceetch
          @Sceetch
          Hi
          I installed the MMM-PIR-Sensor last week and I had a similar problem. I just couldn’t get the sensor to work with the module. I spent a lot of time and tried a few different things and nothing worked… in the end I updated the wiringPi GPIO access library (I’m using a Pi 4 Model B).
          See here:
          http://wiringpi.com/wiringpi-updated-to-2-52-for-the-raspberry-pi-4b/
          And now it’s working OK. I’m not saying this will fix your problem. It may be that an install I did overwrote the wiringPi files on my Pi or rolled them back in some way, but it worked for me.
          Regards
          dbg62
            sdetweil @Sceetch
            @sceetch also i think u need to make sure the sensor actually works
            https://projects.raspberrypi.org/en/projects/parent-detector/3
              Sceetch @sdetweil
              @sdetweil thx for your comment.
              I guess the sensor works.
              If i start this script, the sensor switch after 2 minutes off.
              If the sensor receives movements, the screen turn on, so i think it works. But i will test your script in the evening.
              If there is no movement registered from the sensor the screen switch on after 1 minute.
              I don’t understand why the countdown is 2 min? In the script the delay time is setted by 10 sec.
              And why the screen turns on after another one minute. If there is no signal from the sensor??
                sdetweil @Sceetch
                @sceetch the sensor must be detecting heat difference. its very sensitive. the dial .ust be set to about 2 minutes, since last movement…
                there is a jumper on some of the boards that changes how long it holds the signal active since movement.
                  Sceetch @sdetweil
                  Hi sdetweil, this was a good hint. I think the problem are the adjustments of the sensor itselfs. the time values in my previous post changed now. But the problem still exists.
                  The reason why the screen wake up without movement is, the overlapping of signals. there is one delay in the script, but also one of the Sensor. If the script turns off the screen and the sensor gives also a signal regarding the time delay a little later, the screen will turn on again. so my opinion.
                  But what is now the best adjustment of it?
                  is it possible to inactivate the time delay of the sensor itself?
                  In what position is the jumper to be set?
                  sensivity of it should be clear. thats a customized value for the different situations.
                  S B 2 Replies Last reply Reply Quote 0
                    sdetweil @Sceetch
                    @sceetch google to answer those questions
                      BravoOscar @Sceetch
                      @sceetch
                      I just added a PIR sensor, and I have put jumper on “L” and the two potmeteres on low (clockwise) . This works fine.
                      Here you have som more information on the PIR sensor.
                      https://lastminuteengineers.com/pir-sensor-arduino-tutorial/
                      I use this module:
                      https://github.com/bugsounet/MMM-NewPIR
                      In the config, I have chaged delay from delay: 2 * 60 * 1000 // 2min to delay: 10 * 60 * 1000 //10min
                        jste84
                        I’m having a similar issue using Mmm-PIR-Sensor
                        Using a pi 3b+ and it turns the screen off but not back on again…
                          jste84 @jste84
                          Having tested the commands it looks like
                          sudo tvservice -p doesn’t work with my monitor. (-o works though which is strange?)
                          Vcgencmd works perfectly though…
                          Could this be a reason why it’s not working?
                            sdetweil @jste84
                            @jste84 yes change the command the module uses
                              jste84 @sdetweil
                              @sdetweil is it this line
                              sudo chmod u+s /opt/VC/bin/tvservice && sudo chmod u+s bin/chvt
                              That I need to change? Would I just change TV service to vcgencmd
                                sdetweil @jste84
                                @jste84 maybe. dont know. you could try
                                  Sceetch
                                  @jste84
                                  i guess i have the same issue.
                                  you can try easily with this module
                                  you can change inside the module the mode
                                  mode: 1 - use vgencmd
                                  mode: 3 - use tvservice
                                  in my case it works. But i think i have an adjustment problem.
                                  The screen turns off and also the sensor can wake up the screen again.
                                  But if there is no movement, the screen turn on randomly. Currently i have no solution. I guess there is some wrong settings on sensors Potentiometer.
                                  ebolisaE 1 Reply Last reply Reply Quote 0
                                  • ebolisaE Offline
                                    ebolisa @Sceetch
                                    @sceetch I came to a conclusion to not use any modules which do not show any info on the screen. So, in this case, I use a python script at boot which monitors a PIR and executes an HDMI on/off cmd ;)
