    MMM-CalendarExt2: Black Screen
    30 Posts 3 Posters 11.0k Views 3 Watching
      jack819
      @sdetweil I can barely figure out the simplest tasks on this so I don’t know how that happened. How do I stop that or remove it? The other option (which I would prefer not to do) is I can wipe this all (operating system, etc) and re-install everything.
        sdetweil @jack819
        @jack819 no idea… it might be because of some other app, like pihole,
        J 1 Reply Last reply
          jack819 @sdetweil
          @sdetweil I completely deleted everything off the SD card and reflashed it with the new OS. Then I installed MM again but am still showing the same message and the Calendar is acting the same. Any idea?
            sdetweil @jack819
            @jack819 that makes no sense. how did u install MagicMirror?
            git clone or the automated script?
            neither of those use nginx
              jack819 @sdetweil
              @sdetweil I used this command in terminal (which may be the problem):
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
              It was off a MM website that had a tutorial. I think I will reflash and install another way then see what happens.
                sdetweil @jack819
                @jack819 that’s my script. and what I recommend. it does everything
                it will install pm2 for you
                and u used the pi is, full version to flash the sd card?
                what do you do after the script finishes?
                  jack819 @sdetweil
                  @sdetweil Correct. Used the Pi OS full version. Run the script then once it is done setup for autostart and turn off screensaver. After that I just installed modules.
                    sdetweil @jack819
                    @jack819 the script does pm2 and screensaver already
                    can u show me ~/install.log
                      jack819 @sdetweil
                      @sdetweil Correct. I do that in the script.
                      When I type that command into terminal, it says permission denied.
                        sdetweil @jack819
                        @jack819 show me, means dump , edit, … use some command
                        to type out the file, use the cat command (cat = type in windows)
                        to edit the file use nano
                        nano ~/install.log
                          jack819 @sdetweil
                          @sdetweil Here you go:
                          install starting  - Fri Apr  9 08:58:51 EDT 2021
                          installing on armv7l processor system
                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) $
                          ^[[96mUpdating packages ...^[[90m
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspb$
                          apt-get update  completed ok
                          apt-get upgrade  started
                          apt upgrade result =rc=0 Reading package lists...
                          Building dependency tree...
                          Reading state information...
                          Calculating upgrade...
                          ^[[96mInstalling helper tools ...^[[90m
                          build-essential is already the newest version (12.6).
                          curl is already the newest version (7.64.0-4+deb10u2).
                          git is already the newest version (1:2.20.1-2+deb10u3).
                          unzip is already the newest version (6.0-23+deb10u2).
                          wget is already the newest version (1.20.1-1.1).
                          wget set to manually installed.
                          ^[[96mCheck current Node installation ...^[[0m
                          ^[[93mNode.js is not installed.^[[0m
                          ^[[96mInstalling Node.js ...^[[90m
                          Node release info = ## Installing the NodeSource Node.js 10.x repo... ## Popula$
                          v10.24.1
                          ^[[92mNode.js installation Done! version=v10.24.1^[[0m
                          ^[[96mCheck current NPM installation ...^[[0m
                          ^[[0mNPM currently installed. Checking version number.
                          ^[[0mMinimum npm version: ^[[1mV6.0.0^[[0m
                          ^[[0mInstalled npm version: ^[[1mV6.14.12^[[0m
                          ^[[92mNo npm upgrade necessary.^[[0m
                          ^[[96mCloning MagicMirror ...^[[90m
                          ^[[92mCloning MagicMirror Done!^[[90m
                          package.json update for armv7l completed ok
                          ^[[96mInstalling dependencies ...^[[90m
                          ^[[92mDependencies installation Done!^[[90m
                          fixing sandbox permissions
                          setting up initial config.js
                          ^[[96mCheck plymouth installation ...^[[0m
                          ^[[90mSplashscreen: Checking themes directory.^[[0m
                          ^[[90mSplashscreen: Create theme directory if not exists.^[[0m
                          ^[[92mSplashscreen: Changed theme to MagicMirror successfully.^[[0m
                          install and setup pm2
                          pm2 not installed, installing
                          pm2 install result /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/p$
                          get the pm2 platform specific startup command
                          startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/b$
                          __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                           _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                            _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                             _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                              _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                               _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                                _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                                 _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                  _\///______________\///______________\///__\///////////////__
                                                    Runtime Edition
                                  PM2 is a Production Process Manager for Node.js applications
                                               with a built-in Load Balancer.
                                          Start and Daemonize any application:
                                          $ pm2 start app.js
                                          Load Balance 4 instances of api.js:
                                          $ pm2 start api.js -i 4
                                          Monitor in production:
                                          $ pm2 monitor
                                          Make pm2 auto-boot at server restart:
                                          $ pm2 startup
                                          To go further checkout:
                                          http://pm2.io/
                          [PM2] Init System found: systemd
                          Platform systemd
                          Template
                          [Unit]
                          Description=PM2 process manager
                          Documentation=https://pm2.keymetrics.io/
                          After=network.target
                          [Service]
                          Type=forking
                          User=pi
                          LimitNOFILE=infinity
                          LimitNPROC=infinity
                          LimitCORE=infinity
                          Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/s$
                          Environment=PM2_HOME=/home/pi/.pm2
                          PIDFile=/home/pi/.pm2/pm2.pid
                          Restart=on-failure
                          ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                          ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                          ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                          [Install]
                          WantedBy=multi-user.target
                          Target path
                          /etc/systemd/system/pm2-pi.service
                          Command list
                          [ 'systemctl enable pm2-pi' ]
                          [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                          [PM2] Making script booting at startup...
                          [PM2] [-] Executing: systemctl enable pm2-pi...
                          [PM2] [v] Command successfully executed.
                          [PM2] Freeze a process list on reboot via:
                          $ pm2 save
                          [PM2] Remove init script via:
                          $ pm2 unstartup systemd
                          pm2 startup command done
                          configure the pm2 config file for MagicMirror
                          start MagicMirror via pm2 now
                          save MagicMirror pm2 config now
                          stop MagicMirror via pm2 now
                          disable screensaver via gsettings was true and uint32 300
                          disable screensaver via lightdm.conf
                          disable screensaver via lxsession
                          ^[[92mWe're ready! Run ^[[1m^[[97mpm2 start MagicMirror^[[0m^[[92m from the ~/M$
                          install completed - Fri Apr  9 09:04:39 EDT 2021
