    MMM-GooglePhotos Unhandled promise rejection
    9 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @velkrosmaak
      @velkrosmaak error 429
      https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/429
      • V Offline
        velkrosmaak @sdetweil
        @sdetweil ah heck, how did I miss that?! So I need to increase both of those intervals?
          @velkrosmaak seems so
          • V Offline
            velkrosmaak
            I’m still getting the same error with this.
            My interval values for testing are this at the moment:
             updateInterval: 20000*60,
             scanInterval: 1000*60*60*4,
            According to the Google API docs,
            The quota limit for requests to access media bytes (by loading a photo or video from a base URL) is 75,000 requests per project per day.
            https://developers.google.com/photos/library/guides/api-limits-quotas
            I’m well within that with those values, but am still getting 429s. When it did briefly work it was advancing through images very quickly which makes me think that one of those values is a rate rather than an interval. While i’m brute force guessing the config, is there anyone who’s got this working that can shed any light?
              @velkrosmaak the default updateInterval is 30 seconds
              so, your config looks like this, right
                    module:"MMM-GooglePhotots",
                    position:"....",
                    config : {
                       updateInterval:20000*60,
              settings MUST be inside the config:{} block on every module
              • V Offline
                velkrosmaak
                @sdetweil That’s right, that’s how my config currently is. When it does work, other parameters such as date range, album and sort order are observed so I’m fairly confident it’s valid.
                The docs appear to have changed so I’ve removed ‘scaninterval’ and increased the updateInterval to ‘50000*60’. The problem sadly persists.
                  @velkrosmaak the code in node_helper uses scanInterval
                  if not specified, OR less than 10 minutes
                  this.config.scanInterval < 1000 * 60 * 10
                  it is set to 10 minutes
                  this.config.scanInterval = 1000 * 60 * 10
                  add debug:true to the settings and look at the messages where us start mm…
                  npm start
                  or
                  pm2
                  if pm2, then pm2 logs --lines=100
                  • V Offline
                    @sdetweil I’ve added ‘debug: true,’ inside the config block but I don’t seem to get any other errors regarding the MMM-GooglePhotos module (or any other errors at all in fact) apart from this one below. This is after restarting MM using pm2:
                    pm2 restart mm && pm2 logs --lines=100
                    I’ve also tried it without limiting the lines and I just get this same 429 error over and over.
                    0|mm  | [23.04.2021 00:07.26.515] [ERROR]
                    0|mm  | (node:14901) UnhandledPromiseRejectionWarning: Error: Request failed with status code 429
                    0|mm  |     at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
                    0|mm  |     at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:17:12)
                    0|mm  |     at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:236:11)
                    0|mm  |     at IncomingMessage.emit (events.js:327:22)
                    0|mm  |     at endReadableNT (_stream_readable.js:1220:12)
                    0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
                    0|mm  | [23.04.2021 00:07.26.518] [ERROR]
                    0|mm  | (node:14901) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                    0|mm  | [23.04.2021 00:07.26.521] [ERROR] (node:14901) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                    Thanks so much for the help by the way!
                    1 Reply Last reply Reply Quote -1
