    MMM Pages turn Pages manually
    9 Posts 7 Posters 4.0k Views 7 Watching
      AceTheFire
      Hello.
      I’m using MMM-Pages (https://github.com/edward-shen/MMM-pages) and want to turn Pages manually. I’m already using “MMM-Telegram-Bot” (https://github.com/bugsounet/MMM-TelegramBot) for controlling the mirror. As I can see on github, the Telegram-Bot can use custom command (f.e. sending out notifications). How is it possible to turn the pages manually?
      Maybe it works with the notification “this.sendNotification(“PAGE_CHANGED”, 2);”, but I don’t get that to work…
      AssassinsA unfriendlydeviceU T 3 Replies Last reply Reply Quote 0
      • AssassinsA Offline
        Assassins @AceTheFire
        @acethefire
        Here is my what I have put in config.js.
        rotationTime: 1800000, do it automatic.
        Set it to 0 (Zero), it work here.
              module: 'MMM-pages',
                  [ // Page 1
                    'updatenotification',
                    'currentweather'
                  [ // Page 2
                    'MMM-Telegram-Bot',
                    'calendar'
                  [ // Page 3
                    'clock',
                    'compliments'
                  [ // Page 4
                    'MMM-network-signal',
                    'MMM-ServerStatus'
                fixed: [
                 'clock',
                 'compliments'
          useHttps: false,
          httpsPrivateKey: '',
          httpsCertificate: '',
          logLevel: [
            'INFO',
            'LOG',
            'WARN',
            'ERROR'
          AceTheFire @Assassins
          @assassins so there’s no option to send that notification to turn pages manually?
          • F Offline
            Foxy25
            Hi
            i have installing MMM-Pages to, and i do the changing with MMM-page-indicator.
            MMM-Carousel is also a good choice to change the pages manual.
            Greetings Torsten
              AceTheFire @Foxy25
              @foxy25 thx for your help, but “Page-indicator” isn’t a touch button, isn’t it? I thought it is just an Indicator. How do I change my pages with that module?
                sdetweil @AceTheFire
                @acethefire u may have to add mmm-touch or mmm-buttons to get touchable widgets
                • unfriendlydeviceU Offline
                  unfriendlydevice @AceTheFire
                  @acethefire I’ve used an Android app call KWGT to make a widget on my phone that works with the Tasker app (needs to be purchased) and the RESTask plugin to send a notification to MM to move between pages, I made a PC app in Python to do the same thing which was a lot easier to do than I would have thought! There’s the MM-Remote Android app that has built in buttons for moving between pages.
                  • F Offline
                    Foxy25
                    HI
                    MMM-Carousel and MMM-page-indicator works on a touchscreen.
                    Grettings Torsten
                    • T Offline
                      thobach @AceTheFire
                      @acethefire On https://github.com/edward-shen/MMM-pages#notifications the usable events are described. I use them for example here: https://github.com/thobach/MMM-Gestures/blob/094ef30fe4a7e9204846a4f77d6314b61ee1d758/MMM-Gestures.js#L85
