    Alexa not working
    7 Posts 2 Posters 539 Views 2 Watching
    • L Offline
      laluromeo
      Hello. My Awesome Alexa is not working. All i see is a black screen. A dont know much of programming so please HELP.
        sdetweil @laluromeo
        @laluromeo tell me more.
        was it working?
        how did u install it?
        can you show the messages from where u start mm?
        if npm start, then that terminal window
        if pm2, then pm2 logs–lines=100
        L 2 Replies Last reply Reply Quote 0
        • L Offline
          laluromeo @sdetweil
          Thankyou for answear.
          pi@raspberrypi:~ $ cd MagicMirror
          pi@raspberrypi:~/MagicMirror $ npm run start
          magicmirror@2.15.0 start /home/pi/MagicMirror
          [28.06.2021 17:27.55.653] [LOG] Starting MagicMirror: v2.15.0
          [28.06.2021 17:27.55.673] [LOG] Loading config …
          [28.06.2021 17:27.55.692] [LOG] Loading module helpers …
          [28.06.2021 17:27.58.698] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node-pre-gyp’
          Require stack:
          • /home/pi/MagicMirror/node_modules/snowboy/lib/node/index.js
          • /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js
          [28.06.2021 17:27.58.703] [LOG] Loading module helpers …
          [28.06.2021 17:27.58.720] [ERROR] App threw an error during load
          [28.06.2021 17:27.58.725] [ERROR] Error: Cannot find module ‘node-pre-gyp’
          Require stack:
          • at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
            at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module._load (internal/modules/cjs/loader.js:848:27)
            at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
            at Module.require (internal/modules/cjs/loader.js:1032:19)
            at require (internal/modules/cjs/helpers.js:72:18)
            at Object. (/home/pi/MagicMirror/node_modules/snowboy/lib/node/index.js:6:16)
            at Module._compile (internal/modules/cjs/loader.js:1152:30)
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
            [28.06.2021 17:27.58.731] [ERROR] Whoops! There was an uncaught exception…
            [28.06.2021 17:27.58.749] [ERROR] Error: Cannot find module ‘node-pre-gyp’
            Require stack:
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10) {
            code: ‘MODULE_NOT_FOUND’,
            requireStack: [
            ‘/home/pi/MagicMirror/node_modules/snowboy/lib/node/index.js’,
            ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js’,
            ‘/home/pi/MagicMirror/js/app.js’,
            ‘/home/pi/MagicMirror/js/electron.js’,
            ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
            undefined
            [28.06.2021 17:27.58.757] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [28.06.2021 17:27.58.759] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [28.06.2021 17:27.59.662] [LOG] Launching application.
            sdetweil @laluromeo
            @laluromeo said in Alexa not working:
            node-pre-gyp
            missing dependency, sound like installation not complete
            you had to do the 14 step install process listed on the wiki, right?
            I have a script that does those , I just copy/pasted and made it a script so I didn’t have to type…
            ignore the errors til; the last step
            https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
            • L Offline
              laluromeo @sdetweil
              Never worked, I just installed awesome alexa. The method to install is from MMM-awesome-alexa from modules section @ https://magicmirror.builders/
                sdetweil @laluromeo
                @laluromeo from the doc linked to at that url
                3rd party takes you to the item in the list, click that link takes u to the module home page on github, then
                How to
                Check out the documentation for installation and usage: https://awesome-alexa.js.org
                which then says
                Installing
                First you have to setup your speakers and microphone correctly: Audio setup
                After you have done audio setup you can install Awesome Alexa module to your MagicMirror: Installation
                which then says
                Raspberry Pi Specific Dependencies
                If you are using Raspberry Pi install the following:
                $ sudo apt-get install swig3.0 python-pyaudio python3-pyaudio sox
                $ pip install pyaudio
                Copy to clipboardErrorCopied
                Note: You may need these to get python-pyaudio to work as mentioned here:
                $ sudo apt-get install libasound-dev portaudio19-dev libportaudio2 libportaudiocpp0 ffmpeg libav-tools
                Then install the atlas matrix computing library:
                $ sudo apt-get install libatlas-base-dev
                Step 2. Install Module
                Execute the following commands to install the module:
                Originally from: https://github.com/dolanmiu/MMM-awesome-alexa/issues/164#issuecomment-492951739
                $ cd ~/MagicMirror/modules # Navigate to module folder
                $ git clone https://github.com/dolanmiu/MMM-awesome-alexa.git # Clone this repository
                $ cd MMM-awesome-alexa # go into the module directory
                $ npm install --only=prod # Install depdendencies
                $ cd node_modules
                $ rm -rf snowboy # Remove the installed snowboy
                $ git clone https://github.com/Kitt-AI/snowboy.git # Manually get snowboy from git
                $ cd snowboy # Go into the /snowboy directory
                $ rm -rf node_modules
                $ npm install nan --save # Make sure you install this in the /snowboy directory
                $ npm install node-pre-gyp@0.12.0 --save # Make sure you install this in the /snowboy directory
                $ npm install # Make sure you install in the /snowboy directory
                $ npm run prepublish # Make sure you run this in the /snowboy directory
                $ npm install --save-dev electron-rebuild # Make sure you install this in the /snowboy directory
                $ npm install nan # Make sure you install this in the /snowboy directory
                $ ./node_modules/.bin/electron-rebuild # Build snowboy to your device specifications, in the /snowboy directory
                • L Offline
                  laluromeo @sdetweil
                  @sdetweil Thank You. I Reinstalled for the second time. Now it work just fine.
