    Just updated Mirror, now mirror will not work.
    14 Posts 2 Posters 4.1k Views 2 Watching
      sdetweil @Nneuland
      @nneuland well, there are others reporting similar problems…
      not sure what the problem is yet
      • N
        Nneuland @sdetweil
        Ohhhh no. Ok. At least I’m not going mad alone. Thank you for letting me know
          sdetweil @Nneuland
          @nneuland but fresh install doesn’t seem to have the problem…
          use my script, it never fails…
          rename the existing MagicMirror folder
          then run the install script.
          see https://github.com/sdetweil/MagicMirror_scripts
          then u can copy your modules over and config.js from the renamed folder
          • N
            Nneuland @sdetweil
            Saved again by Sam/. Thank you so very much
            • N
              Nneuland @Nneuland
              @sdetweil I think I celebrated too early.
              Very odd thing happening. I’ve lost all of my modules. Back to default. What in the world did I do now?
                sdetweil @Nneuland
                @nneuland did u copy your stuff over? from the old to the new? including config.js?
                rename the new modules/default folder out of the way for the copy
                then from the new modules folder
                cp -r -p ~/Magicmirror-old/modules .
                then rm -rf default
                and rename the saved default folder back
                • N
                  Nneuland @sdetweil
                  yeah. Just getting a black screen and a cursor.
                    sdetweil @Nneuland
                    @nneuland black screen, look at the messages where u start MagicMirror
                    npm start
                    or pm2
                    if pm2, then the pm2 logs --lines=100
                    will show the same messages
                    • N
                      Nneuland @sdetweil
                      you’re right
                      [09.07.2021 21:41.21.879] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                      Require stack:
                      • /home/pi/MagicMirror/modules/MMM-CoinMarketCap/node_helper.js
                      not sure why
                        sdetweil @Nneuland
                        @nneuland because request was removed in the latest release, as it has security issue that could not be fixed., and all users recommended to get on to something else ( aka deprecated)
                        in the short term
                        npm install request
                        • N
                          Nneuland @sdetweil
                          You’re a gentleman and a scholar!!!
