    Can't get weather to load
    1 Posts 1 Posters 470 Views 1 Watching
    • B
      bisbister1
      Re: I can't get the weather to load
      I’m having the same problem. I’ve edited by config to change other modules successfully, but weather never works. I confirmed that my API call works when I type it raw into a webpage search bar. DevMode shows this error
      DarkSky API as failed to load resource, HTTP status 404
      Failed to load No ‘Access-Control-Allow-Origin’ header is present on the requested resource. Origin ‘http://localhost:8080’ is therefore not allowed access. The response had HTTP status code 404.
      I tried ipWhitelist [], port: 8080 and no luck.
      I’ve been knocking around on this for a month with no luck. My mirror project is a dud without weather.
