    Getting Google Contacts birthdays into Calendar
    6 Posts 2 Posters 3.0k Views 3 Watching
      bolish
      For those interested in below issue solving :
      • Google Contact birth calendar doesn’t offer .ics so it’s impossible to get it automatically into MM calendar
      • I’ve wrote a quick google script that you can use as below :
      1/ Create an empty personnal “birthday calendar” into Google Agenda (remind the ID of the calendar into calendar parameters for later)
      2/ Create a new google script which you can store into your Google drive
      3/ Paste below code into the script :
      function Sync_Birth_Cal() {
        // Calendars adress (ID)
        var calendarSource = CalendarApp.getCalendarById("THE ID OF YOUR CONTACT CALENDAR");
        var calendarDestination = CalendarApp.getCalendarById("THE ID OF THE CREATED CALENDAR");
        // Start and End Date definition
        var Today = new Date();
        var StartDeleteDate = new Date();
        var EndDeleteDate = new Date();
        var StartCopyDate = new Date();
        var EndCopyDate = new Date();
        StartDeleteDate.setDate(Today.getDate()-400);
        EndDeleteDate.setDate(Today.getDate()+400);
        StartCopyDate.setDate(Today.getDate()-360);
        EndCopyDate.setDate(Today.getDate()+360);
        // first deletes all datas in calendar
        var eventToDelete = calendarDestination.getEvents(StartDeleteDate, EndDeleteDate);
         for (var i = 0; i < eventToDelete.length; i++) {
          eventToDelete[i].deleteEvent();
        // then copy everything again
        var eventToCopy = calendarSource.getEvents(StartCopyDate, EndCopyDate);
        for (var t in eventToCopy){
          var newEvent = calendarDestination.createEvent(eventToCopy[t].getTitle(), eventToCopy[t].getStartTime(), eventToCopy[t].getEndTime());
      4/ Into Google script, Edit, Add trigger (choose the one you want, I personally choose to launch that one every 2 hours, but you can do whatever you want)
      5/ You can know use the .ics path of the newly created calendar into your MM calendar
      NOTE : it’s the first time I write that kind of stuff. It works for me until now, but there could be some bugs also. Let’s see.
      NOTE 2 : be careful… part of the script is deleting calendars events on purpose… So don’t mess up…If needed, back up before.
      Regards
        MwMagicMirror
        @bolish said in Getting Google Contacts birthdays into Calendar:
        var calendarSource = CalendarApp.getCalendarById(“THE ID OF YOUR CONTACT CALENDAR”);
        var calendarDestination = CalendarApp.getCalendarById(“THE ID OF THE CREATED CALENDAR”);
        I get this error when I try to run the script:
        TypeError: Cannot call method “getEvents” of null. (line 25, file “Code”)
        I got that sorted, forgot the 2 IDs.
        Now I get:
        Service invoked too many times in a short time: calendar. Try Utilities.sleep(1000) between calls. (line 37, file “Code”)
        MW
          bolish
          Hi @MwMagicMirror ,
          I didn’t got this specific error on my side but I got another one :
          • Mine was “too much invokes for one day” : I reduce the “every 2 hours triggers” to once a day + modified the time range from +/-400 to something less (copying before today date was useless)
          For your error, indeed, I’ve read somewhere on google that implementing a “sleep timer” between invokes could solve it.
          I just tried that and it works on my side (I don’t know if it will solve your issue as I don’t got the same) :
            var calendarSource = CalendarApp.getCalendarById("ID1");
            var calendarDestination = CalendarApp.getCalendarById("ID2");
            StartDeleteDate.setDate(Today.getDate()-10);
            EndDeleteDate.setDate(Today.getDate()+70);
            StartCopyDate.setDate(Today.getDate()-2);
            EndCopyDate.setDate(Today.getDate()+60);
               Utilities.sleep(1000); /// add a timer
              Utilities.sleep(1000); // add a timer
            MwMagicMirror @bolish
            @bolish
            That got it for me, you did have the eventToDelete[i].deleteEvent(); outside the for loop, anyway its working like it should now.
            tyvm
            MW
              bolish
              @MwMagicMirror Happy it helped someone!!
              What do you mean by “was outside the loop”? Can you please show me the mistake?
              Tx
                MwMagicMirror
                Thats what I noticed, anyway its all good, dont see that issue in any code now.
                Also I noticed that my birthday calendar has all my appointments and such. I see the logic is basically copying my main calendar into the birthday calendar. I manually delete everything out of my birthday calendar except for the birthdays, all is good…until…the script runs again then I back to having everything in my birthday calendar.
                MW
