    MMM-PIR doesn´t turn off monitor since update MM 2.7
    25 Posts 9 Posters 11.9k Views 9 Watching
      sdetweil @FruityBebbles
      @FruityBebbles sorry, could you tell me more?? same what?
      can’t tell how far back u are responding…
        sdetweil @shgmongohh
        @shgmongohh just fyi… the npm audit fix will NOT fix everything… these are warnings anyhow… so, no problems
          sdetweil @djay07
          @djay07 @lxne @FruityBebbles ok, node_helper missing… heres how to fix
          cd ~/MagicMirror
          git checkout modules/node_modules/node_helper/index.js
          then restart your magic mirror however you do it… reboot, pm2, some script. npm start
          • P Offline
            Paxan
            I could make it work by moving the module in the config file to the very bottom.
            • F Offline
              FruityBebbles @sdetweil
              @sdetweil sorry for the confusion. I see how I wasn’t making much sense…
              I am so out of my realm when dealing with all of this computery stuff, despite being tech-savvy but I was having an issue with my PIR sensor not turning putting everything to sleep.
              The module would simply put my Pi to sleep, but I would still have a “No signal” message show up on the screen (indicating no HDMI)…
              Idk what I did, exactly but after combing through different queries and reading other’s questions on the subject, it seems to be working, now.
              My PIR sensor does put everything to sleep and works like a charm.
              You guys on the forum are so much nicer than 99.9% of the internet =)
              • 3 / 3
