    MMM-Myweather doesn't work, only black screen
    4 Posts 2 Posters 1.7k Views 2 Watching
    • M
      matsjanssen
      Dear all,
      I installed currently the MMM-myweather module but it wont work.
      I only see a black space were it should look. Can someone help me?
      code_text
      			module: "alert",
          		  module: 'MMM-MyWeather',
          		  position: 'top_left',
            		    	apikey: "####", // private; don't share!
            		    	lat: '51.95', // Culemborg, NL ;)
            		    	lon: '5.23', // use the quotes!
            		    	hourly: '1',
            		    	fctext: '1',
            		    	fcdaycount: "5",
            		    	fcdaystart: "0",
            		    	hourlyinterval: "3",
            		    	hourlycount: "2",
            		    	alerttime: 10000,
            		    	alerttruncatestring: "english:",
            		    	roundTmpDecs: 1,
            		    	UseCardinals: 0,
            		    	layout: "horizontal",
        sdetweil @matsjanssen
        @matsjanssen open the developers window, ctrl-shift-i, and select the console tab, and scroll up to find any errors, (red text)…
        also, the module names are case sensitive , so check that ‘MMM-myweather’ exactly matches what was installed in the mm/modules folder, and specified in config.js
        • M
          matsjanssen
          I see some red text but don’t know how to fix it.
          weatherforecast is suspended.
          api.openweathermap.org/data/2.5/forecast/daily?id=5128581&units=metric&lang=en&APPID=YOUR_OPENWEATHER_API_KEY:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
          weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
          weatherRequest.onreadystatechange @ weatherforecast.js:266
          3api.openweathermap.org/data/2.5/forecast?id=5128581&units=metric&lang=en&APPID=YOUR_OPENWEATHER_API_KEY:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
          weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast?id=5128581&units=metric&lang=en&APPID=YOUR_OPENWEATHER_API_KEY 401 (Unauthorized)
          updateWeather @ weatherforecast.js:279
          (anonymous) @ weatherforecast.js:400
          setTimeout (async)
          scheduleUpdate @ weatherforecast.js:399
          weatherRequest.onreadystatechange @ weatherforecast.js:275
          XMLHttpRequest.send (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
            @matsjanssen openweather gives different keys for different things. 4 day vs long term the key u have cannot get the weather info u asked for. Error=401.
            Not authorized.
            Update your key
