    Unable to install MMM-RTSPStream due to missing dependencies
    1 Posts 1 Posters 806 Views 1 Watching
    • bmadeiraB Offline
      bmadeira
      Hello,
      I was trying to install MMM-RTSPStream today and npm fails everytime with ecstatic dependency not met:
      pi@mdr-mm:~/MagicMirror/modules/MMM-RTSPStream $ npm install
      npm WARN deprecated datauri@1.1.0: Datauri 2.0 released. See more in https://github.com/data-uri/datauri/releases/tag/v2.0.0
      npm WARN deprecated mimer@0.3.2: Mimer 1.0 released. See more in https://github.com/data-uri/mimer/releases/tag/v1.0.0
      MMM-RTSPStream@1.2.2 postinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
      sudo npm i -g http-server
      npm ERR! code ETARGET
      npm ERR! notarget No matching version found for ecstatic@^3.0.0
      npm ERR! notarget In most cases you or one of your dependencies are requesting
      npm ERR! notarget a package version that doesn’t exist.
      npm ERR! notarget
      npm ERR! notarget It was specified as a dependency of ‘http-server’
      npm ERR! notarget
      npm ERR! /root/.npm/_logs/2019-05-02T21_57_30_835Z-debug.log
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! MMM-RTSPStream@1.2.2 postinstall: sudo npm i -g http-server
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the MMM-RTSPStream@1.2.2 postinstall script.
      npm ERR! /home/pi/.npm/_logs/2019-05-02T21_57_31_267Z-debug.log
      I found out that ecstatic 3.x.x was removed and only version 4.1.2 exists, leaving me unable to install http-server:
      pi@mdr-mm:~ $ npm view ecstatic versions --json
      “4.1.2”
      @shbatm , it it possible for you to update your code to overcome this problem?
      Regards,
      Bruno
