    Magic Mirror Mac Mini npm start
    18 Posts 3 Posters 6.4k Views 3 Watching
      drx1984
      hello together, I found the Magic Mirror for me a short time ago and I think it’s really cool. My Magic Mirror run on a Mac Mini and runs very stable and fluid. Can someone tell me how I can solve it when I start the Mac Mini that also starts Magic Mirror together ??? Do not want to open terminal every time and enter npm start. Does anyone have an idea how I can solve that ?? Thanks a lot & sorry for the bad translation.
        sdetweil @drx1984
        @drx1984 if u used the installer, it should have setup a pm2 module to auto start mm in boot.
        From your shell, can you try
        pm2 list
          drx1984
          @sdetweil said in Magic Mirror Mac Mini npm start:
          I have used this installation description.
          do I have to install something else???
          https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
            drx1984 @sdetweil
            @sdetweil Now I have PM2 modules through this installation guide.
            But when I restart the Mac Mini, MagicMirror does not start by itself.
            https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
              drx1984 @sdetweil
              ok so?
                sdetweil @drx1984
                @drx1984 I am sure the mm setup failed when it did the pm2 setup, as it is hard coded to user pi.
                I think if you do
                pm2 start ~/MagicMirror/installers/mm.sh
                pm2 save
                It will work on boot
                  @sdetweil did the mirror app start?
                    drx1984 @sdetweil
                    Yes starts, Now I try to restart the MacMini and see if Magic Mirror starts automatically
                      drx1984 @sdetweil
                      @sdetweil pity MagicMirror does not start automatically after reboot
                        drx1984
                        Does anyone have Magic Mirror on the Mac Mini on the run???
                        How does she do that with the autostart??
                        • ? Offline
                          A Former User
                          forget pm2. this could be a help.
                          https://stackoverflow.com/questions/6442364/running-script-upon-login-mac
                            drx1984 @Guest
                            @Sean
                            thanks, do I need to write a script?
                            • ? Offline
                              A Former User @drx1984
                              @drx1984
                              Wait a second. After trial on my mac, I’ll post for you. (And I think pm2 could also be available with launchd)
                                drx1984 @Guest
                                @Sean ok, that would be very nice
                                • ? Offline
                                  @drx1984
                                  Ok. I found incredibly simple solution.
                                  sudo pm2 startup darwin
                                  That’s all. It is already served by pm2 since https://github.com/Unitech/pm2/pull/936
                                  (It will take a few seconds until MM starts from bootup)
                                    drx1984 @Guest
                                    @Sean said in Magic Mirror Mac Mini npm start:
                                    ok thanks the command: sudo pm2 startup darwin tonight test and report you.
                                    Many Thanks
                                      drx1984 @Guest
                                      @Sean I just tried, unfortunately I get an error message. Do you know how I can solve this?
                                      Thank you
                                      • ? Offline
                                        Hmmm… For me it works.
                                        Check ~/Library/LaunchAgents/directory whether exists or not.
                                        You can save your xml (under Template) totarget path by manual then execute command list
